Sounds like your main circuit breaker is tripping out. Try disconnecting the starter and see if it still does it, you may have a sort or a bad starter.
Cheers
I ran my multimeter across and read nothing I un hooded the starter and it didn't screw up so I guess the starter is bad .I cant understand why the power goes away when the starter is bad though on my shovel it always made a weird noise or sumthing but no power to anything and the fact that it just up and quit it baffles me
Push the starter button, let the system kick itself off. Now start on one end or the other with your multimeter and find where the +12V stops. For example, with everything tripped off, black lead on a known good ground or the battery negative, red lead: Touch the + on the battery. 12.xV? Touch the solenoid terminal with the battery lead. +12V? Touch the main circuit breaker (wherever it is, it's under the seat on my bike) both sides. +12V on both? Tell us what you get with those tests and we'll go from there.
Sorry Bro. but i have said this now 100 times !!!
What in particular are you ****ing talking about ???
We are here to help but without any detailed info. we are in the dark as you are .
When you go to the Doctor do you say , im hurtin ?
Come on with some info. to give us a clue and we will give you the help .
Hey doc I thought the center pin on the relay shut off the headlight while starting.
Hey THC,
Mine doesn't. If yours does, they either changed in inbetween the years or someone modded it. One of the suggestions for avoiding The Dreaded Click is to add a relay to turn off the headlight when there's no oil pressure by having the relay controlled by the oil pressure light. That way when you are cranking it, the headlight is off.
Hey THC,
See post 10 in the adding a relay sticky.
This was being discussed by two people way smarter than me.
