Which charging components are correct?
Old Aug 26, 2013 | 01:00 PM
Redbeard69's Avatar
Redbeard69
Default Which charging components are correct?
I've been skulking around here for a few days now reading threads and trying to figure this out for myself.
I recently bought a 98 FLHTCUI and found that the charging system wasn't working.
After doing the tests based on the info I found here, I figured out that the stator is toast.
I've been trying to find what I thought was the correct charging set for it but am unsure at this point.
The service bible says it's a 45amp stator. but I can't find one anywhere. 38amp seams to be the highest.
What is 3 phase? how do I know which one I have?
Please advise. I'm starting to have withdrawals from my sled sitting in the garage.
Thanks.
Old Aug 26, 2013 | 01:08 PM
RidemyEVO's Avatar
RidemyEVO
You can install whichever size "charging system" you like as long as you replace all the same amps. The bigger the better. I went with a cyclelectric system for mine , it is 3 phase.
Old Aug 26, 2013 | 01:11 PM
RidemyEVO's Avatar
RidemyEVO
Here's a link for cycleelectric http://www.cycleelectricinc.com/ may help to clear things up a bit more.
Old Aug 26, 2013 | 01:24 PM
Redbeard69's Avatar
Redbeard69
Thanks Lynn, I'll give them a call.
Crashrdking01
Electrical/Lighting/Alarm
Feb 7, 2019 08:57 PM
Skeezmachine
Sep 8, 2014 11:59 AM
CROM
Shovelhead
Aug 14, 2011 05:09 PM
bigdaddysdaddy
Oct 23, 2010 10:48 PM
Rigid Rider 57
Shovelhead
Jul 26, 2007 12:54 AM
