Charging System ??
Old Jul 25, 2007 | 03:25 PM
Rigid Rider 57's Avatar
Rigid Rider 57
Default Charging System ??
I have a 76 1200 Shovel that may be developing a charging system problem. I don't have the test equipment the service manual calls for to check the stator and regulator so my questions is, what voltage should I read if I go directly toone of thestator pins with a volt meter? This is the 2 pin stator.
Old Jul 26, 2007 | 12:54 AM
ardvark's Avatar
ardvark
Default RE: Charging System ??
I had the same problem check out this thread https://www.hdforums.com/m_1911489/tm.htmabout 15 posts below yours - I'll bump it to the top for you.
Jim Dawson
Electrical/Lighting/Alarm
Apr 28, 2014 03:21 PM
Hipolito
May 26, 2012 07:50 AM
the motor shop
Dec 13, 2011 06:16 PM
kencarr
Sep 3, 2007 06:57 AM
Sleeps In Trees
May 7, 2007 12:56 AM
