Electrical troubleshoot
Old Oct 8, 2013 | 08:30 AM
MJHJEA's Avatar
MJHJEA
Default Electrical troubleshoot
Alright, 4 or 5 weeks ago I had an isse that happened after washing my bike (95 heritage). The neutral light wouldn't come on and there was a clicking noise coming from inside the console....a couple clicks every 5 seconds or so. I rode it into work that day and 8 hours later the bike was fine. I figured something had gotten wet ( then dried out) and I had no other issue with it until yesterday, after another washing ( I've washed it a few times in between with no problem). I rode her into work thinking it would dry out again like last time, but with the thought that I definately need to troubleshoot it. When I left work at 11 pm, not only were the symptoms still there, but more. Along with the neutral light unlit and the clicking noise, the speedo light was going off and on, and I had no headlight or tree lights except the turn signals. My ride home is through the dark countryside, so even with using the turn signals for light, it was a rather scary ride home. I was wondering with what I'm describing with the new symptoms, does it hint to the first place I should be checking....I suck at electrical issues. Thanks
Old Oct 8, 2013 | 09:26 AM
Hackd's Avatar
Hackd
Start with the basics: Battery and grounds. Then work your way up to the other things. 18 year old bike, is going to have loose wires, which translates into bad connections.
Clicking noise could be from a circuit breaker. Meaning a short somewhere, or a worn out breaker.
Diagnosing wiring issues are tough, and often time consuming. Do the simple stuff first, get yourself a continuity tester.
Old Oct 8, 2013 | 09:44 AM
Dr.Hess's Avatar
Dr.Hess
Gosh, here, take this magic pill that's only $500 and everything will be great. That's what everyone wants.
Or, you can try reading this thread and this post:
https://www.hdforums.com/forum/11772561-post7.html
but it's a lot more work.
Old Oct 8, 2013 | 02:06 PM
Spanners39's Avatar
Spanners39
You might have a component that is now full of water, a circuit breaker or similar....even a relay but basically water has got where water doesn't need to be.
Track it down and waterproof it...
Old Oct 8, 2013 | 09:38 PM
Tee&Vee's Avatar
Tee&Vee
here is my evidence of YOUR problem, our problem brudda, but I show you my solution, or so i hopes....
Last edited by Tee⋁ Oct 8, 2013 at 10:18 PM. Reason: can't do it from a mobile? whatever
Old Oct 8, 2013 | 09:47 PM
Tee&Vee's Avatar
Tee&Vee
Hmmm, didn't work too well... Lemme see if i can make it a direct link, i always screw this crap up
Old Oct 8, 2013 | 09:48 PM
Tee&Vee's Avatar
Tee&Vee
Nope. Lemme send it to YouTube then directly post it here.
Sowwwwy
Old Oct 8, 2013 | 09:53 PM
QC's Avatar
QC
Where's Traildog when you need him and his Seafoam?
Oh, and stop washing your bike!
Old Oct 10, 2013 | 09:38 AM
grbrown's Avatar
grbrown
The clicking is probably a thermal cutout, protecting the wet part of your electrics! You may find you have a poor ground or loose connector somewhere, which the water has aggravated. Trace, clean and dry, protect and tighten!
marvo75
May 18, 2013 10:06 PM
rancid13
Apr 12, 2013 07:41 AM
Harleyman5691
Mar 25, 2013 07:41 AM
Sullyboy
Aug 3, 2009 09:34 AM
AdrianVall
Sep 16, 2008 04:20 PM
