When fire meets ice...
Old Oct 25, 2013 | 06:14 PM
traildog's Avatar
traildog
No SEAFOAM for you!
Old Oct 25, 2013 | 08:27 PM
McMurphy's Avatar
McMurphy
Thats how we used to put bearings on when I built laser scanners. Put the bearings in the freezer.....next to the employees tv dinners.....and heat the shafts in the pizza oven......and wallah....
Yep about three seconds and it wont move....so get it right the first time!
Murph
Old Oct 25, 2013 | 08:43 PM
zimm's Avatar
zimm
Scott at hillside said the new gear will be no problem. I'll let you know how that turns out. I don't know.
Old Oct 25, 2013 | 10:38 PM
HarDlife's Avatar
HarDlife
My VT cam was supplied without a gear. I wanted to reuse mine anyway, the motor was so quiet and smooth (for a Harley) that I didn't want to change anything unless I had to.
Old Oct 26, 2013 | 06:51 AM
grbrown's Avatar
grbrown
We can buy an aerosol can of freezing agent from a plumbers' suppliers, which will probably provide enough freezing to install a cam and bearing.
Old Oct 26, 2013 | 07:48 AM
Tom84FXST's Avatar
Tom84FXST
IMO putting a camshaft in liquid nitrogen is a really bad idea...you just performed cryogenic hardening...not a good idea on a camshaft...the cheapest press made would install it in 30 seconds.
http://en.wikipedia.org/wiki/Cryogenic_hardening
Old Oct 26, 2013 | 08:02 AM
traildog's Avatar
traildog
Is there ANY possibility of slippage?
Old Oct 26, 2013 | 08:45 AM
HarDlife's Avatar
HarDlife
Cryogenic hardening - Wikipedia, the free encyclopedia
I agree. Putting it directly in liquid nitrogen would be a bad idea. I put it in a container and partially immersed the container in LN2, and only left it in there for a short duration. I mic'd all journals before and after, and specs are same. I am not advocating this method, but I think it will be okay. We'll see. ..
Old Oct 26, 2013 | 09:19 AM
HarDlife's Avatar
HarDlife
Check out www.metal-wear.com
They cryogenically treat camshafts, as well as other internal engine parts, to increase strength and wear resistance.
Old Oct 26, 2013 | 11:16 AM
Tom84FXST's Avatar
Tom84FXST
Yeah but not something you could do on your kitchen table...lol. Place where I worked send out mill parts to be treated all the time...that's why I know about it. Not just any steel would work...we had to get it from Germany. What you did will be fine...didn't know you didn't directly expose it.
