Another question for you guys
Old Nov 21, 2013 | 11:00 PM
misfitJason's Avatar
misfitJason
Mounted my motor in the new frame and it's square except the left front mount. It has a gap of three thousands (0.03) (I think that's right it's very very very thin). Is that too much when tightened down. I assume I will probably have to shim that. What do you guys think. Thanks in advance.
Old Nov 21, 2013 | 11:10 PM
DeJavu's Avatar
DeJavu
Shim it, the last thing you want to do is put any additional stress on the cases. Seems like the frame engine mounts are not level, is it possible the frame is slightly twisted?
Old Nov 21, 2013 | 11:12 PM
Rootro's Avatar
Rootro
Shim it.
Old Nov 22, 2013 | 07:20 AM
johnjzjz's Avatar
johnjzjz
if the block pads are painted than when the paint brakes away ( tightening it up )
it might go the other way - frame pads usually are not off on one side only -
we remove all the paint in the area thats painted on the pads, and brush it on after the install saves all the guessing - johnjzjz
Old Nov 22, 2013 | 09:48 AM
misfitJason
The mounting blocks are bare. My bad I should have said that.
Old Nov 22, 2013 | 10:20 AM
panz4ever's Avatar
panz4ever
Use brass shim stock. The last thing you need/want is a broken case motor mount.
Glide79
Shovelhead
Jul 11, 2015 08:50 AM
Scaredofrain
Powdercoat & Paint
13
Nov 22, 2012 08:33 PM
98glider
Ironhead
Nov 7, 2010 08:30 PM
timberwolfz28
Aug 25, 2008 11:04 AM
glebo
Jun 5, 2007 05:20 PM
