How the hell?...
Old Dec 20, 2013 | 10:21 PM
HarDlife's Avatar
HarDlife
Default How the hell?...
....do you guys adjust the idle mixture screw with the stock ac in place?
Old Dec 20, 2013 | 10:34 PM
Spanners39's Avatar
Spanners39
With a sawed off screwdriver.
Old Dec 20, 2013 | 10:43 PM
HarDlife's Avatar
HarDlife
And how does one manipulate said screwdriver in such a ridiculously confined space?
Old Dec 21, 2013 | 12:24 AM
LowriderHarold's Avatar
LowriderHarold
Default One of these?
http://www.ebay.com/itm/271260452011...ht_1369wt_1124
This looks like a handy little adjustment screw.hth
Ride Safe,
Harold
Old Dec 21, 2013 | 01:04 AM
HarDlife's Avatar
HarDlife
Thanks Harold, but I'm talking about fuel mixture screw, not the idle speed screw.
Anyone use the CVP EZ adjust screw? Trying to do it with a screwdriver seems next to impossible, unless I'm missing something.
Old Dec 21, 2013 | 01:46 AM
Spanners39's Avatar
Spanners39
Slide it up into the slot, support it with left hand in a V for Victory sign and turn it with the right hand....takes patience and practice.
Old Dec 21, 2013 | 02:59 AM
traildog's Avatar
traildog
Hmmmm, My adjustment screws are REALLY easy to get to. Oh, Wait, I have a good (S&S) carb....Never Mind.....
Old Dec 21, 2013 | 04:28 AM
tmanbuckhunter's Avatar
tmanbuckhunter
Get the CV Performance screw driver thing.
Old Dec 21, 2013 | 05:40 AM
Imold's Avatar
Imold
That's just mean...
But yeah, my S&S is the carb Harley should have designed.
What I do with a similar problem - my older sporty has a damned hot crossover pipe right in the way; I just tweak it with the ac off, then give the screw about 1/8th turn either direction and hold the ac on and see where the rpm goes; you should be able to see which direction to go, and then continue like that till you get it. I keep telling myself I probably won't ever have to tweak it again and don't get one of those extended screws, and then cuss the next time I have to tweak it.
Old Dec 21, 2013 | 06:28 AM
Moog Player's Avatar
Moog Player
I use a Motion Pro Pilot Screw Adj. Tool (08-0119). Easy as falling off a fat girl.
