Spot The Difference
Old Jan 11, 2014 | 02:14 PM
Spanners39's Avatar
Spanners39
Originally Posted by Doug S
That's all that matters, good job!!
I'd like to replace the front wheel on mine but not sure about the shimming and don't have a trust worthy indy around.... Don't you need some sort of end play or runout guage to do it?
Ds
If the wheel you fit was shimmed correctly on the donor bike then it will be correct on your bike.
I had a complete mare because the wheel had been modified and was running an extended spacer tube, no stepped washer and no shims. It had been set too tight and the outer races had gone oval.
Messed with my head for a bit that did until I looked up the part number and then googled it and ended up on the Custom Chrome site, they sell an aftermarket spacer and conveniently listed the correct length (4.308")...so off to the lathe we go, get hold of a shim kit and washer, some new wheel bearings (free of charge from the Indy who supplied the wheel) and it was easy after that.
The real find in the this project was the American Enginuity top handle bar clamp. Usually 240 USD, my Indy gave it to me for free because they didn't know where they had got it from or what it was worth and I am a good customer...plus they were on a guilt trip over the bearings in the wheel.
You need these to relocate the idiot lights from the visor. Joker machine do a cheaper one that only works with the idiot lights that sit in the speedo mount but you can make it work.
Old Jan 11, 2014 | 03:55 PM
Hackd's Avatar
Hackd
I like it.
Originally Posted by Spanners39
I had a complete mare...
This I'm not so sure about....
Old Jan 11, 2014 | 04:24 PM
Spanners39's Avatar
Spanners39
Originally Posted by Hackd
I like it.
Nightmare
Old Jan 11, 2014 | 04:48 PM
Whitey1's Avatar
Whitey1
I like your new front end setup, but what is really awesome is the view from your driveway as shown in the last picture. Nice.
Old Jan 11, 2014 | 04:58 PM
Spanners39's Avatar
Spanners39
Thanks, we love were we live.....that pic doesn't do the location justice
Old Jan 11, 2014 | 05:03 PM
Kees's Avatar
Kees
Yep it's an awesome spot in the world alright.....the steep curving gravel driveway is a good test....
Old Jan 11, 2014 | 07:14 PM
Spanners39's Avatar
Spanners39
So far only a chick on a Sporty has managed to come to grief.....the trick is rear brake, first gear DO NOT PANIC!!!!
Old Jan 11, 2014 | 07:55 PM
traildog's Avatar
traildog
Nightmare
Yes, you are.........
Old Jan 11, 2014 | 08:34 PM
Spanners39's Avatar
Spanners39
http://www.bing.com/videos/search?q=...4B5F47E9C60229
Not safe for work or home....
Old Jan 11, 2014 | 11:13 PM
HarDlife's Avatar
HarDlife
So that is your stock 39 mm legs in wide glide trees?
