Spot The Difference
I'd like to replace the front wheel on mine but not sure about the shimming and don't have a trust worthy indy around.... Don't you need some sort of end play or runout guage to do it?
Ds
remove seals, clean grease from bearings and races,
assemble axle, spacers, shims, bearings into wheel with no seals, find a suitable spacer so you can torque the axle nut.
But don't just torque the nut fully in case it's too tight, don't want to screw up the bearings.
Check in and out play of axle as you aproach the spec'ed torque.
When torque is reached, you should still feel some end play, less is better, as long as you have some.
Check at every 1/4 turn of the axle to ensure no binding.
add or remove shims as needed.
Its way more stable on the cruise through straight or slightly bendy roads.
Same place as the triple trees, Vulcanworks on EBay, the triples trees are seriously lovely, fender looks like crap in the raw but once its painted it looks way beefier. http://www.ebay.com/itm/16-Front-Fen...item1c272dce3a
Vulcan sent me the wrong rotor spacers so I had them turned down to 5.2mm and they worked just fine.
