Mikuni Tuning, Detonation
Old Jan 23, 2014 | 07:01 AM
deuce40s's Avatar
deuce40s
Turning the air screw in on a Mikuni reduces air into the idle system, making it richer. Most of the pinging is coming in 4th gear, hard acceleration generally from 40-65mph. I can do it in 5th as well if I have enough room to get my speed up.
I think there's several things out of whack on this carb. The float bowl overflow tube has been occasionally dripping fuel. Would this indicate my float bowl is sticking up or is too high? It seems to measure the correct height according to the manual.
I also have learned that I'm probably tuning the idle system incorrectly. I'm setting the idle around 1k RPMs with the screw two turns out and then trying to get the bike to stumble. I believe I should be dropping the idle as low as possible with the screw two turns out and finding the stumble from there. I'll have to wait until the bike thaws out to try anything.
Old Jan 23, 2014 | 07:02 AM
Schex's Avatar
Schex
Turning the AIR screw out leans the mixture, and actually affects the mixture all the way to wot, but to a lesser degree as the throttle is opened.
Old Jan 23, 2014 | 11:46 AM
1997bagger's Avatar
1997bagger
You guys are correct on the mixture screw, been awhile since I touched mine. From tuning with a wego system I had low, cruise and wot set, reset my idle afr to 14.2 from 14 6 and rode it. The low speed afr also got richer, didn't see any changes In mid. I'll babble what I noticed with a wego when I get home
Old Jan 23, 2014 | 06:20 PM
1997bagger's Avatar
1997bagger
If I remember Joe mentions the more aggressive needle with higher compression and detonation prone engine, check that accellerator nozzle jet and the rod adjustment. I have the 50 with the full rod travel and no issues with a Mikuni 45 and the aggressive needle.
Another thing to double check is the timing module set up right by the TDC method per instructions, if it is off a little could be out of range of adjustments and still be advanced or check the timing with a timing light to know for sure the timing is correct. You are in the roll on throttle problem area under load but shouldn't detonate when you get out of that area with those jets, the only other way to know for sure is a AFR gauge which takes the guesswork out of it.
Old Mar 1, 2014 | 10:47 AM
Deuce1977's Avatar
Deuce1977
3rd Gear
On my 2000 Deuce I have the Mikuni HSR45. Maybe a larger Mikuni is the answer?
I bought the bike like this, sO i really dont know anything about carb sizes..
I also have 4 spark plugs and a Crane Cam TC88 along with it.
Old Mar 6, 2015 | 08:23 AM
dynawg1's Avatar
dynawg1
If anything, the Mikuni 45 is TOO BIG for your motor unless it is 117ci or larger and/or has very aggressive cams and Stage 4+ headwork. For a stock through Stage 3 88/95/98ci motor, the Mikuni 42 is a better match.
Old Mar 6, 2015 | 09:36 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Default do this.....
it definitely sounds like You're a little rich on you're slow circuit. If you were lean you would be pinging every where not just at higher rpm's. set your ignition curve to 3 and test drive. If that cures it then you are going to need to download dynatek software, get the patch cable and build your curve for your bike. Sounds more like to much timing too soon........to do that set switch 2 to off and switch 3 to on.. or a bad voes
Old Mar 6, 2015 | 11:24 PM
Hopper's Avatar
Hopper
That is exactly the scenario the VOES is designed to remedy. I would be fitting one asap.
... The float bowl overflow tube has been occasionally dripping fuel. Would this indicate my float bowl is sticking up or is too high? It seems to measure the correct height according to the manual.
Yes, that indicates something wrong with the float valve and/or float level. Might be as simple as crud in the valve and seat area. Or you may need a new float needle. Get a good Mikuni one. The cheap aftermarket ones leak past from the get-go.
A leaking float valve or high float setting will make the bike run rich at idle as the excess fuel slops down the carb throat. Which then causes you to set the idle mixture wrong without knowing it.
But I would put my money on the VOES being the cause of your detonation.
Old Mar 7, 2015 | 07:01 AM
92Fatty's Avatar
92Fatty
I'd be pulling the bowl anytime I'm having fuel overflow. Who's to say how much is seeping into motor when sitting in storage. Also check on that VOES wire. Great info above.
Old Mar 7, 2015 | 07:19 AM
Owtlaw's Avatar
Owtlaw
Original post is over a year old. It's probably fixed.....
