Installed an air horn today
Turns out the horn has a bracket on it that holds the factory nut and allows you to get the nut close to the rubber isolater, the slip on the horn and rotate the horn until it's really tight.
I'm thinking I may put some locktite on it just to be safe.
It doesn't look bad to me. Hardly noticeable. Here is a before and after shot.
It also came with a relay, but I figured the factory horn must have a relay on it...so I tried it using the factory wires and works fine.
Overall about a 3 minute install.
I will say, it's very loud, easily twice as loud as the factory horns. Between this and my loud pipes I hope to get people's attention when I want to.
I tested it at 102 DB on my iPhone sound meter. Plenty loud.
Also installed speed bleeders and bled the brakes, front lever is a lot better, I had a bit of air in there. I do love speed bleeders, use them on my Vette as well. Not much to take a picture of with that mod however.
I probably will run the relay one of these days. I have to take the seat off which is a bit of a pain on my bike. Well if you can call 6 bolts a pain, I guess.
So far I'm very pleased with the mod.
