Carb issue that needs a lil help
Old Mar 10, 2014 | 08:57 PM
92Fatty's Avatar
92Fatty
Did you try and adjust air/fuel mixture screw with the new jet? Does it have any effect when you adjust it?
Old Mar 10, 2014 | 09:36 PM
brentswth20's Avatar
brentswth20
Nope, not yet but I will try that tomorrow when I get outta work.
Old Mar 11, 2014 | 10:56 PM
brentswth20
It took some adjusting but everything finally worked together! The fast idle worked well and it was running real lean, but I adjusted, took it for a ride and no stalls or stops. When Friday comes around though, I'll start looking for a CV
Thanks for the help everybody!
Old Mar 12, 2014 | 12:55 AM
92Fatty's Avatar
92Fatty
Glad you figured it out. You didn't even need seafoam. You will appreciate CV upgrade from what I have heard from Shovel owners that have upgraded.
Old Mar 12, 2014 | 10:12 PM
brentswth20
Does anyone have one of those CVs you're recommending?
Old Mar 12, 2014 | 10:36 PM
92Fatty's Avatar
92Fatty
There are a chitload around. Ebay is your best bet to find a used one quick. You can also get a hot cv from there also. It would not surprise me if a sponsor on this forum sells them.
Old Mar 14, 2014 | 12:00 PM
Beemervet's Avatar
Beemervet
http://www.ebay.com/itm/Harley-Evo-S...3fe195&vxp=mtr
Old Apr 3, 2014 | 08:38 PM
brentswth20
Okay so I got the new CV carb and its a model 27412-99c. I put everything on and it was popping out of the carb. Noticed the carb was going in crooked to the intake manifold so I straightened it out. Well I started it back up and it's idling really fast. I sprayed around the carb to check for leaks --> no difference, messed with the choke *** thinking maybe the choke was just stuck --> no difference, took off the throttle cable --> no difference, and adjusted out the idle screw until it no longer even touches. After trying all these, the idle is still very high on this.
Is there something I am missing?
Old Apr 3, 2014 | 09:01 PM
amasoniii's Avatar
amasoniii
Did you adjust the air mixture screw?
Old Apr 3, 2014 | 09:08 PM
brentswth20
Yeah it was seeming not to help at all either
