Base Gasket Bubble
The rest of you boys can pound it sideways .
Pretty sure it's full of dino oil since I picked it up at a dealer last spring. So I can't blame the synthetic stuff.
One of my Evo's blows Bubbles. Hell I though it was cute. 'Cept mine is blowing little bitty bubbles. Bubbles is Bubbles to me. Air in the oil? I have to admit I though that was humorous too. As we all know, the base gaskets are leaking. Mine doesn't leak enough to drip (I don't think). The kicker is the location of the bubbles... it's away from the oil feed so, it's pressure from the bottom end (and not oil pressure). It's on the Bob-ster so I don't care.
My question is how serious is this and how hard is this to fix? Haven't wrenched much so taking it a shop may be an option.
Sometimes a base gasket can weep for a long time, but sometimes they get messy in a hurry.
Murphy`s law says it will be fine until you are into riding season...
Since it is not summer yet, you have plenty of time. Pull the jug off and have your machinist true the bottom surface and re assemble. James, Cometic or OEM gaskets. Follow the torque procedure supplied with the gaskets, or the service manual if you use OEM gaskets.
If you do the job yourself, follow the service manual, pay special attention to the process for removing/installing the lower rocker supports and pushrods.
Lots of guys here can talk you through the process if you decide to do it yourself, even when we are arguing...
Can air get trapped in a motor like that though? I wouldn't think so if the motor is breathing properly, and if it wasn't it would be finding a place to breathe, like a weeping base gasket causing it to bubble. So much to learn, and so little time on this rotating mud ball.
And just to clear the air in here a bit all I ever said is a pair jumped me and didn't manage to kick mine I held my own , you hunter are the one turning that all around so fugging drop it tool or get the story straight I don't care which .
