evo or another twincam?
ride both and you'll feel the difference between both engines.
To me, a Tc feels somewhat generic, but thats me...
If you're a handy person, get a EVO, do some minor upgrades, add or loose some chrome
And you'll still get it better and cheaper than a Tc!!
They both have there good points, and warts. The tc need to be separated into four groups.
The 01-02 were the best motor with the tightest tolerances, timken bearings, but you have to do regular mantaince or change out the tentioners.
The 96's have eleminated that, have more power, but the tolerances are getting worse.
The 10+ are a wiring nightmare, no need to carry a tool kit with these, any problem it is going into the dealer for a computer checkup.
Biggest problem with the tc is it's a great design that got hacked to death by the accounting department.
Still these motors go 150k on a top end, with regular maintenance.
Stock parts are cheap, due to take off from people wanting more power, even full motors.
The new trend is tc motors in evo frames.
Talk about a split personality.
I would not have Fuel injection, especially the early years.
I think the secret is buying a clean, unmolested low mile bike that was someone's trophy.
When bikes get old and ridden, electronic get corroded, plastic deteriorate, start breaking.
Get the cleanest taken care of bike that you can afford.
OP I'd agree with the others who said stay away from the earliest evo's and the fuel injected ones, mid 90's bikes are great!
The bathtub shape of the TC is much more efficient than the d shape of the evo, plus the squish zones of the TC are placed by design, not necessity because of valve angle, causing better controlled turbulence in the combustion chamber.
Its pretty easy to get one horse per cube on a TC, where getting that out of a EVO is much much harder. Given the displacement of a TC 88 compared to a 82 cu EVO, this adds up pretty fast, then you have the 96, 103, 110, ect you can see the advantage of the larger displacement motor that does not have to strain or be pushed to the maximum to make the power.
Also want to look at the efficiency of the TC, it is common for a TC to get 45-50 mpg where I have not heard of many cases of EVO doing that and this as well as the hp is due to the head design, and the twin cam.
. These people with 255's or whatever else they get (555?) Get les than 15% more performance. Still faster than a stage one Evo but a stage two with decked heads polished chambers and the like... I'd take me chances on the Evo.Their pricing is higher since they almost always pay somebody to do their work for them. Lol
Good debate!
Tom
This brings up a point however OP I guess a part of your decision should be made on how much power you want or need
I don't think the Harley motor would have a chance in hell but I could be wrong.
