Issue #3...
Old Apr 8, 2014 | 09:54 PM
Beemervet's Avatar
Beemervet
Is the derby cover the factory unit? Whether or not, before you try to reseal it, find a piece of glass or other perfectly flat surface to check the cover. It will never seal if it is warped.
Old Apr 8, 2014 | 10:40 PM
AAAC's Avatar
AAAC
Thanks for the feedback! No, it's not. Just about everything on this bike has been changed out. If it is warped, is it possible to straighten it, or am I stuck with buying a new derby cover? I take that back...it may be factory but it's not the stock cover.
Old Apr 9, 2014 | 09:32 AM
Beemervet's Avatar
Beemervet
I've never seen anyone successfully straighten one out, but maybe it can be done.
Old Apr 9, 2014 | 09:36 AM
Scudda's Avatar
Scudda
My bike calls for 3 quarts at an oil change. I always only use 2.5 quarts just for this reason!
Old Apr 9, 2014 | 09:47 AM
hvacgaspiping's Avatar
hvacgaspiping
Originally Posted by Owtlaw
What Spanners said..... Don't try to hit the top mark on the oil stick. Aim for halfway between the marks.
And don`t check your oil when the engine is cold. I always check mine just a couple of minutes after I shut it down when I pull into the garage.
Old Apr 9, 2014 | 09:49 AM
hvacgaspiping
Nada, it`s a cast part.
Old Apr 9, 2014 | 10:37 AM
grbrown's Avatar
grbrown
The small sheet of glass is a great idea, for checking if it is flat. If it is not too warped it can be straightened, or corrected, but that is a skill I learned early in life and haven't done it for many years! I had an old thick plate glass mirror that was perfect.
jsb1022
Aug 6, 2014 12:19 AM
BigTwins
Sep 5, 2013 08:15 PM
Greg11
Jun 29, 2011 04:47 PM
GNick
Sep 9, 2010 09:31 PM
jitz80
Jul 13, 2010 07:21 AM
