what would cause this?
Old May 23, 2014 | 07:52 AM
JohnnyC's Avatar
JohnnyC
Originally Posted by Kabear
End gap was not set on the rings, top ring bent and caused the rise in the upper landing, then piston cracked and a lean mixture took care of the rest.
Just my .02
This seems plausible. But a (overhaul) mechanic should have been checking that on a rebuild.
I was curious to know for sure if the break-in process and set-up (timing) might have had something to do with it too?
I have mine offset 2 degrees and can really tell a difference between running when it's first warmed up, and when it's well heated up after being on the road for a short while.
Since the overhaul it's been a whole different motor and runs like brand new with just the top end rebuilt. The change to 9.6:1 from 8.5:1, and the .30 over can really be felt in acceleration. And the smoothness of the rebuild running is noticed at cruising speeds. Also the clatter is gone. Can't believe how worn the old top end was at 61K.
Once again, best wishes taking care of your situation.
Old May 23, 2014 | 07:59 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
When you say offset are you talking about advanced or retarded?
Old May 23, 2014 | 08:50 AM
JohnnyC's Avatar
JohnnyC
"HYPEREUTECTIC PISTONS: The low thermal conductivity of this alloy requires engines running hypereutectic pistons to reduce total ignition timing 2 to 4 degrees. Final timing may vary with your application."
Retarded.
I think this is why I feel a difference in running when warmed up, and later when really heated up. When heated up it responds with excitement. When warmed up it has a slight hesitation when giving it WOT.
But I admit my old butterfly carb need replacing, and to get optimum performance a set of better pipes is needed too. Soon I hope!!
Old May 23, 2014 | 09:12 PM
RHillbilly's Avatar
RHillbilly
Rings not gapped when they get hot they butt together can pull the whole top off of piston
Old May 23, 2014 | 10:12 PM
Tom84FXST's Avatar
Tom84FXST
Correct answer...KB pistons come with a warning about this.
Old May 25, 2014 | 07:02 AM
junglejoe's Avatar
junglejoe
It's a MIX of things that caused this....Hope you get back together soon! SUCKS!!
Old May 25, 2014 | 07:17 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
For those folks that may not know the difference between pre igniton (quick engine killer) and detonation (what we hear as pinging).
Here`s a link to a good description.
http://www.streetrodstuff.com/Articl...ne/Detonation/
Old May 28, 2014 | 10:43 AM
Schulte94's Avatar
Schulte94
Well I guess the extra ring gap (or lack there of) would be the main contributor to my problem! What I don't understand is why the pistons didn't come with that handy dandy sheet. If I would have known that I wouldn't be dropping another $600. And only JE makes pistons that are 3.518 and 10.5:1 compression. It doesn't make sense that it took that long to do it though. My break in method was that of mototune, I wasn't easy on it... and why wouldn't the front cylinder have done the same thing? Oh well the great mystery I guess...
Old May 28, 2014 | 11:23 AM
johnjzjz's Avatar
johnjzjz
the pistons you had ran .0008 to .0015 for piston to wall
the JEs want .0035 or even a little more depends on what your doing and the bikes weight and other stuff ask your guy what he thinks AND they are not quiet they do get better hot
in my shop we would not want that much compression in that over size .030 piston as evos are thin to begin with -- just my take
Old May 28, 2014 | 02:34 PM
JohnnyC's Avatar
JohnnyC
Interesting this came up again. I checked my box and the instructions were in it. Turns out they are .20. I thought I was told they were .30.
And in talking with their tech service I was informed the statement about a 2 to 4 degree retard was only to keep people from advancing the timing and causing critical issues. I was told this was the idea of a company tech many, many years ago.
I was told, and as is in the instructions "FINAL TIMING MAY VARY WITH YOUR APPLICATION". It has more to do with adjusting to where the motor runs the best and dyno testing would be the best to have it run precisley at it's peak and not cause damage.
I now know this wasn't the issue with the piston ring situation in the photos on this thread.
