fuel guage issue
Old May 29, 2014 | 09:14 AM
RidemyEVO's Avatar
RidemyEVO
Default fuel guage issue
Hi guys
Been doing some pre trouble shooting before I dive in. On my 89 flhtp if I have a full tank of gas the gas gauge shows full like normal and after approximately 70 km off the full tank the gauge seems to go down to 3/4 and starts to bounce a bit below 3/4 then starts to head to empty and back up to 3/4 again. After a few more kilometers are gone by the gauge goes to empty and stays there. All this is done while traveling steady on the hiway.
Any thoughts on this before I start in.
Thanks
Lynn
Old May 29, 2014 | 09:33 AM
Dr.Hess's Avatar
Dr.Hess
Sender is dirty or broken. Take it out of the tank and inspect it.
Old May 29, 2014 | 09:55 AM
RidemyEVO's Avatar
RidemyEVO
Thanks Doc Hess, was thinking the same as it did have an empty tank all winter in storage.
Old May 29, 2014 | 10:00 AM
Beemervet's Avatar
Beemervet
Better to have a completely full tank in storage.
Old May 29, 2014 | 11:10 AM
falconbrother's Avatar
falconbrother
For storing add some Seafoam (not a full bottle) and fill the tank with gas. In the spring you will be in good shape. This is what I do with my motorhome in the late fall (but I add a few bottles). I do start the generator every few weeks but, the gas stays good and everything works in spring.
Old May 30, 2014 | 12:38 PM
RidemyEVO's Avatar
RidemyEVO
Absolutely correct and usually I do as a habit but some how it got past me.
Old May 30, 2014 | 12:40 PM
RidemyEVO's Avatar
RidemyEVO
Pulled the scensor and it was corroded and only seemed to contact at full. After some fiddling the contact is worse and seems to have some play so reviving is a no go. Looks like the old girl will get a replacement.
Thanks
Old May 31, 2014 | 05:24 PM
RidemyEVO's Avatar
RidemyEVO
Ok I've been doing some searching but can't nail down a fuel sending unit. Can you guys tell me what year to year of flht will fit my bike as well as other models that may fit? This would be a great help.
Thanks
Old May 31, 2014 | 06:53 PM
Dr.Hess's Avatar
Dr.Hess
I think they are NLA. You'll have to find the part number and call around to try to find a dealer that has one.
Old May 31, 2014 | 07:00 PM
RidemyEVO's Avatar
RidemyEVO
OK I give up, what is NLA?
Thanks
