3 phase charging system for 91flhtcu?
Old Jun 4, 2014 | 07:42 PM
team423's Avatar
team423
Default 3 phase charging system for 91flhtcu?
So my stator went out the other day. .My question is what size amp system should I go with 40 or 50?Its a 91ultra..thanks in advance. .
Old Jun 4, 2014 | 08:21 PM
Dr.Hess's Avatar
Dr.Hess
When mine finally goes, I'll go with the 32 amp 29985-87, which I think you have already. Are you running a boom bike or something? 1KW sub woofer?
Old Jun 5, 2014 | 05:22 AM
Schex's Avatar
Schex
I stuck with the standard 32 amp system on my '90 Ultra for several reasons, adequate charging, less parasitic drag, not as expensive, and mostly, when I'm on road trips, if I would have a regulator problem, almost any dealer or indy should have one in stock.
Old Jun 13, 2014 | 07:25 PM
team423's Avatar
team423
Who makes and sells a good stock replacement 32 amp thats not sky high?
Old Jun 13, 2014 | 07:38 PM
Freebirdsride1's Avatar
Freebirdsride1
on my 90 ultra in installed a 50amp I like it
Old Jun 13, 2014 | 07:51 PM
machinehed's Avatar
machinehed
Default alt. replacement.
Before you go throwing money around for parts . I would look for the reason why your original stator burned up ?
Check the seal at the location were the stator wires exit the primary case and look for a short to ground there. This is usually the cause of a stator burn out.
Old Jun 13, 2014 | 08:21 PM
Dr.Hess's Avatar
Dr.Hess
That wouldn't really matter, machinehed, as that's getting replaced with the new stator anyway. But I agree, look for a reason. In my experience, if it's a common thing, it is usually a short somewhere that you'll never find unless you're looking for something else.
Old Jun 13, 2014 | 09:19 PM
RLH3175's Avatar
RLH3175
When I replaced the voltage regulator on my 1996 Ultra Classic, I was told by the HD shop that it was a 38 amp system.
Old Jun 13, 2014 | 09:21 PM
johnod's Avatar
johnod
I recently got this thru Amazon, 115 shipped.
Cycle Electric Stator CE-3845-97
Old Jun 14, 2014 | 12:31 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Did you get the regulator and rotor to go with it?
