Help! 1997 FI Evo Problem
Old Jun 19, 2014 | 10:12 PM
user 59756875865's Avatar
user 59756875865
Default Help! 1997 FI Evo Problem
my 97 ultra had a noise last fall so i tore it down over the winter to find the problem. long story short bad lifter was on the brink of taking out cam. so Andrews ev27 cam new lifters and adjustable push-rods (decked heads .050) and valve job. so the whole valve train is new. put it all back together over the past few weeks here and now it wont start. turns over fine but front injector is flooding front cylinder and rear is dry as a bone. swapped injectors around same problem. spark is good push-rods are right. im out of ideas any help?
Old Jun 19, 2014 | 11:03 PM
cowboy 51's Avatar
cowboy 51
if I read that right , you swapped injectors around & the front still flooded, if that the case it's electic double check wire lead to rear injector for power
user 59756875865
Jun 19, 2014 10:14 PM
NamVet69
Jun 11, 2013 08:20 PM
jrscars
Nov 19, 2012 01:17 PM
chopperhead2
Exhaust System Topics
Oct 4, 2008 09:11 PM
murf1
EVO
14
Apr 7, 2008 07:24 PM
