Lifter Noise
Did you adjust each cylinder at a time, I mean both valves on a particular cylinder at once?
Trust me, if you have a pushtube too loose - it'll be gosh awful noise!
but no distict loud ticking. "Big Boys Head Porting" has a good tech article on
adjusting the pushrods, I have the Revtec ChromeMoly pushrods in mine.
***** quote ******
Turn the engine over (by hand) until you see the cam overlap for the rear cylinder.
That is when exhaust lifter is traveling down and the intake lifter is traveling up
(closing the exhaust valve and opening the intake valve).
Once you find that for the rear cylinder, the FRONT cylinder will be on its compression stroke.
You can now adjust the front cylinder pushrods.
With the pushrods loose, tighten them until there is no up and down play.
The pushrods should be able to rotate easily with your fingers but should
not move up and down any.
******* end quote ****
http://www.bigboyzheadporting.com/forumdisplay.php?f=6
on edit: Oh , I forgot, I did have some top end rattling that was related to detonation, the EV-27 will ping
really quick with compression over 9.5 to 1. I had to back off on the timing advance curve (using the crane Hi-4).
You are asking for opinions somewhat, so here's mine. I don't use anything made by Revtec (Wrecktec) at our shop. We will install partspurchased by a customer elsewhere, but will not warranty them. Revtec components are made overseas, so who knows what materials they are made out of, what the clearances/tolerances are and so forth. There is a reason why those parts are less expensive.
That being said, the HD "B" lifter is excellent and a set is around $100.00 from a discount HD dealer such as Zanotti's. I sell Revolution Performance (V-Thunder), lifters for about the same price + shipping. The lifterscome with a lifetime warranty, although I would change them out as routine mainenance at 40K anyways.
Do you know the TPI count on your pushrods? 4.0 turns from 0 lash sounds like an awful lot of preload. Most pushrods are 32TPI, some are 24TPI and Revtec pushrods should be 36TPI.The EV-27 makes some noise due to the fast ramp design, but should not be overly so. I try to use the factory gear on a cam swap whenever possible to avoid the gear whine as well. You could also have a bad lifter, or lifters. My current EV27 with the SE lifters is not overlynoisy.
I'll be changing cams shortly to a 585 lift V-Thunder with the V-Thunder lifters and SE pushrods that are 32TPI. My installation instructions state 2.5 turns from 0 lash.
I would first determine/comfirm the thread count on the pushrod. Try readjusting with less preload and see if the lifter noise improves. If so, then you know they were preloaded too much and problem is solved.If not, I'd recommend replacing the lifters and readjust to the lifter makers factory recommendations for your pushrod TPI count.
Typically, cam gears have a spot of paint to denote the pitch of the teeth. I've only installed one Andrews and it was NOT marked. If your noise is coming from near the lifters, rather than the valves and rockers, most likely your cam gear is too small and the teeth of the cam gear are hitting the backside of the pinion as the cam comes off to the back side.
