Starter relay ground wire location?
Old Jun 20, 2014 | 09:14 AM
rpmpit's Avatar
rpmpit
Default Starter relay ground wire location?
88 FLST with Heartland 250 conversion. The plastic piece on the front lower portion of the rear fender where the relay and main cb were mounted is replaced with what they call a rock guard. I call it the front/lower rear fender. So I made a bracket to mount the relay and main cb in approximately the same location. Now I have to find a new spot to terminate the frame ground wire. Can someone tell me where it was grounded in the stock set-up? I took a lot of pre disassembly pics but unfortunately none show the location of that ground wire. Thanks!
Old Jun 21, 2014 | 03:31 AM
Pinetop's Avatar
Pinetop
forward bolt of starter to frame, i.e. back of inner primary.
Pinetop
Old Jun 23, 2014 | 06:58 AM
rpmpit's Avatar
rpmpit
Thank you! Do you mean one of the long through bolts that attach the starter? I can pull off the chrome cover and one of the nuts holding on the bracket to the transmission and terminate it there. What do you think?
Pinetop
Old Jun 26, 2014 | 09:08 AM
rpmpit's Avatar
rpmpit
bump
Old Jun 26, 2014 | 09:19 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
You have 2 bolts that attach your starter to the inner primary.
The front one is easier to get to.
I don't think either has a chrome cover.
Old Jun 27, 2014 | 08:02 AM
rpmpit's Avatar
rpmpit
I'm talking about the round chrome cover on the end of the starter. It has to be removed to access the 2 long bolts that connect the starter to the inner primary. To me they seem equally accessible but the rear bolt is closer to the relay. Sorry if I'm misunderstanding. I really appreciate the help.
Old Jun 27, 2014 | 09:53 AM
texashillcountry
Dirt don't hurt
Look between the starter and the top of the tranny and you should see an allen head bolt on the inside of the inner primary.
That is what we are talking about.
I think it is a 1/4-20 bolt.
Old Jun 27, 2014 | 09:55 AM
texashillcountry
Dirt don't hurt
Nope I'm wrong it is bigger than 1/4-20 but I don't remember what size it is.
Old Jun 27, 2014 | 11:06 AM
rpmpit's Avatar
rpmpit
Ok, will check it out when I get home. Thanks!!
Bulldog1085
Shovelhead
Feb 18, 2019 05:45 PM
misfitJason
EVO
22
Dec 23, 2018 10:52 AM
Dr. Fell
Electrical/Lighting/Alarm
Mar 23, 2014 07:53 AM
Johnandadz
Sep 21, 2012 10:54 AM
AlgorNick
EVO
Jun 19, 2011 08:00 PM
