No Fire!
Old Jun 29, 2014 | 03:27 PM
Hillcapper's Avatar
Hillcapper
Default No Fire!
Took my '88 fxsts out today to warm it up to change oil and she died on me about 1/2 mile from house. Looked to be out of gas (I know) so had the boy bring me some gas. Got her started went back to the house, running rough still. Decided to ride it up to the gas station, on the way she died and would not start. Bike is cranking over fine, getting gas (at least at carb) not getting any fire at plugs. I picked this bike up recently, got a great deal on it and all it needed was a clutch. Has ran great up until now. I have power at both sides of the coil and coil ground seems ok. Any suggestions to help me short cut some diagnostics?
Thanks all
Old Jun 29, 2014 | 03:57 PM
traildog's Avatar
traildog
Sounds like what happened when my ignition switch gave up on me.
Lights and signals working?
Old Jun 29, 2014 | 05:16 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Deleted.
Last edited by Dan89FLSTC; Jun 29, 2014 at 07:51 PM. Reason: Electrical prob, not carb(didn`t read op`s post carefully)
Old Jun 29, 2014 | 05:43 PM
Spanners39's Avatar
Spanners39
Try new plugs, Evos are fussy about plugs....
Old Jun 29, 2014 | 07:28 PM
machinehed's Avatar
machinehed
Default no fire at pluggs
Thanks all
If no fire at pluggs you need to check the ign. system.
Be sure you have no fire at plugs or just bad plugs.
Determine which .?
Old Jun 29, 2014 | 07:36 PM
Jim Kraft's Avatar
Jim Kraft
Sounds like the sensor under the cam cover to me. If you have power at the coil the sensor may not be triggering the coil. They do go bad and generally quit after warming up.
Old Jun 29, 2014 | 07:49 PM
Spanners39's Avatar
Spanners39
If it starts again once the motor is fully cold then its very likely to be the ign pick up.
Old Jun 29, 2014 | 07:53 PM
Hillcapper's Avatar
Hillcapper
I did forget to mention I just installed a new ignition switch, no issues though, lights work cranks when it should etc... Dont think its carb issue, have fuel coming through jet when you twist the throttle and its a S and S Super E. I will replace plugs but find it hard to believe they both failed at the same time. Sensor under cam cover sounds like a possibility. How do you check the coil for output?
Thanks again....
Old Jun 29, 2014 | 07:55 PM
Hillcapper's Avatar
Hillcapper
Is that under the cam cover?
Old Jun 29, 2014 | 08:13 PM
Dr.Hess's Avatar
Dr.Hess
It's under the ignition cover. Next to your right foot, in the cone. There are tests in the book. If, after pulling the cover, you see black goo, that's the problem. If no black goo, it could still be bad.
