evo FXR wont start
Old Jul 10, 2014 | 07:19 PM
pieisgood's Avatar
pieisgood
Default evo FXR wont start
My fxr hadnt been ridden in a few weeks so I went to the garage to start it up and take it out and it wouldnt start. When I push the ignition button all I hear is a click it doesnt sound like the starter turns over at all. I threw the charger on it and had it tested with no solution. Any ideas where to start? Any help is much appreciated.
Old Jul 10, 2014 | 07:30 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Grab your volt meter and make sure you are getting full battery voltage at your starter.
If not replace starter relay and try again.
Old Jul 10, 2014 | 07:51 PM
pieisgood's Avatar
pieisgood
Mind walking me through how to do that? I struggle with electrical on a bike.
Old Jul 10, 2014 | 07:58 PM
texashillcountry
Dirt don't hurt
First question is do you have an OEM service manual?
I don't have an FXR and it will tell you where to find the various parts.
To check if you are getting full battery voltage at the starter look for a 16 gauge wire (mine is green) on the right side of your starter.
It should have a female spade connector.
Pull it off the starter and hook your positive lead to that and ground your negative lead.
Hit the start button and see what your volt meter reads.
If you want PM me your number and I will talk you through it.
Old Jul 10, 2014 | 09:08 PM
92Fatty's Avatar
92Fatty
I'd check and make sure battery connections are clean. Sometimes they look clean until you put a wrench to them.
Old Jul 11, 2014 | 04:50 PM
pieisgood's Avatar
pieisgood
Where are my fuses at? I checked under the cover on right side and there isnt anything there, and no fuses under left side cover. This bike was rewired at one point.
Old Jul 11, 2014 | 06:24 PM
texashillcountry
Dirt don't hurt
What year bike do you have?
My '95 FLSTC came from the factory with no fusses at all.
Just thermal breakers.
Old Jul 12, 2014 | 10:47 PM
pieisgood's Avatar
pieisgood
It is a 92 fxrs. Found the fuse, it was hidden pretty well. Swapped it out and it started right up!
Old Jul 12, 2014 | 11:11 PM
texashillcountry
Dirt don't hurt
Just out of curiosity where was it?
Old Jul 13, 2014 | 12:26 AM
PanHeadRich's Avatar
PanHeadRich
Very cool, can't get anymore helpful than that
