Rear motor mount
Old Jul 13, 2014 | 05:04 AM
br549A1's Avatar
br549A1
Originally Posted by Son of PMS
Thanks KP, came to the same conclusion after a thorough examination.
I'm thinking the True-Track stop bolt won't adjust to specs because the PO shimmed the front mount. I suppose I'll pull the shims and see.
Right now I'm on dinner break from bleeding the back MC. Had to disassemble the rear brake to get the True - Track in. It better be worth it.
Thanks for all the help everyone. I'll report back later.
I'm not sold on the shim thing, the only way a shim should be required is if your rear mount was sagging excessively allowing the engine to pull off the front, then you should replace the rear, not shim the front. I said it before, I still think alot of these claimed vibration repairs by replacing the front mount are simply masking another problem. If you want more stability the vibratechnics mount makes a big difference, it also absorbs alot. When I replaced my rear it shifted the position of the engine, but I noticed no difference otherwise except being short $116 I can't get back.
Old Jul 13, 2014 | 09:34 AM
Son of PMS's Avatar
Son of PMS
Originally Posted by grbrown
After a while I removed that 'adjuster' on my Dyna. As an engineer I could see no purpose for it. Despite tightening it when first installing the kit it came undone and jammed the front mount. A big twin can truly vibrate when under duress! So consider removing yours, or removing the lock nut and tightening the bolt home, to fill the hole.
Yeah I can't figure out what that bolt is supposed to do.
Old Jul 13, 2014 | 02:18 PM
Son of PMS's Avatar
Son of PMS
True-Track is in, shims are out. Alignment checked and good. Did the HD service bulletin M-1324 for vibration issues. The only thing different in M-1324 is running the bike with the rear wheel off the ground while all mounts are loose. Initial 10 mile test run shows possibly a bit less vibration and it's slightly different. 58 to 62 is now tolerable.
I'll try to post that bulletin when I'm not posting via phone if anybody's interested.
Old Jul 13, 2014 | 09:01 PM
98glider's Avatar
98glider
Yes please
Old Jul 13, 2014 | 10:19 PM
Son of PMS's Avatar
Son of PMS
Here ya go. It seems to make some minor difference.
Old Jul 13, 2014 | 10:44 PM
Son of PMS's Avatar
Son of PMS
The True-Track definitely makes my bike less squirrely on the interstate at 70 - 80 mph. It seems to handle the twisties better but I'm a geezer and don't really push it anymore.
Old Jul 14, 2014 | 04:55 PM
Son of PMS's Avatar
Son of PMS
I emailed True-Track about that stop bolt.
This is their reply:
The limiter is to keep the rockerbox from hitting the frame should the motor mount break. What is the distance you are presently able to achieve?
Customer Service
True-Track, Inc | Rear Suspension Stabilization Experts
Direct: 818-623-0697 | Fax: 818-623-8705 | Tech: 818-445-6204
sales@true-track.com | http://www.true-track.com
Old Jul 15, 2014 | 04:52 AM
grbrown's Avatar
grbrown
Thumbs up
"The limiter is to keep the rockerbox from hitting the frame should the motor mount break. What is the distance you are presently able to achieve?"
That's interesting to know. They could usefully include that in the instructions! If you leave it in, smother it in Loctite, so the darned thing doesn't come unscrewed, as mine did.
Old Jul 22, 2014 | 08:39 PM
Son of PMS's Avatar
Son of PMS
This is the latest from True-Track:
What we can tell you is that when the clearance can't be brought to the specs indicated the mount is already sagging, or worn, and we do suggest changing both out at that point. I know you indicated you had the bike one year and the PO one year. We've seen mounts worn at 7,000.
Stiggy
Nov 16, 2023 11:14 AM
dynawg1
Apr 1, 2015 08:37 AM
JohnnyRebKY
Jun 10, 2014 11:47 AM
JohnnyRebKY
Jun 8, 2014 09:22 PM
Brettfullthrottle
EVO
23
Jul 19, 2009 07:33 PM
