Shovelhead guy joining Evo guys
Old Jul 23, 2014 | 07:32 AM
grbrown's Avatar
grbrown
Another shovel chap here, my first new Harley. As for your gear-change problem my 1990 bike, bought new, broke its gear-lever return spring. When we change gear, that spring returns the lever to the natural position, from which we can make the next gear change. It resets the internal positive stop mechanism, in the gear selector.
If my diagnosis is correct, you should find you can change gear (I rode mine a lot like this) by using your toe to return the lever to its proper place. The long-term solution is to replace that spring, which costs a few dollars, but requires a lot of effort to get to. I had mine done, but IIRC it involves removing the primary drive, so you can remove the gear cluster from the trans casing, to get at the darned spring!
Old Jul 23, 2014 | 07:37 AM
br549A1's Avatar
br549A1
Looks like you picked up a nice looking project. Can we hear what you stole it for?
Old Jul 23, 2014 | 09:23 AM
RidemyEVO's Avatar
RidemyEVO
Been there fixed it. Just as Graham post 11 described. Nice bike by the way and 90 was better year then the earlier evos, lots of good changes.
Old Jul 23, 2014 | 10:13 AM
92Fatty's Avatar
92Fatty
I know the dealer used to say that is the $400 spring that actually cost $5 the rest was labor.
Old Jul 23, 2014 | 10:17 AM
grbrown's Avatar
grbrown
Thumbs up
That's the one!
Old Jul 23, 2014 | 10:30 AM
rivercityslim's Avatar
rivercityslim
Had the same issue with my '89 last fall. As Graham described it is shiftable as is, but definitely a PIA. Also as Graham mentioned, the spring itself is easy and cheap to come by (it will be in stock just about anywhere - my local indy had one, didn't even have to go to the dealer), but replacing it requires a fair amount of disassembly.
Old Jul 23, 2014 | 11:58 AM
MIKE93SVT's Avatar
MIKE93SVT
$2,200, I'll snap some better pics today. About to head out there
Thanks for the comments. I read up on the repair, just another thing to learn.
Mike
Old Jul 23, 2014 | 12:04 PM
Dr.Hess's Avatar
Dr.Hess
I would go with "stole it."
Old Jul 23, 2014 | 12:11 PM
br549A1's Avatar
br549A1
Wow $2,200 is an amazing deal. Good work and good luck.
Old Jul 23, 2014 | 02:29 PM
92Fatty's Avatar
92Fatty
The figure the previous owner thought the trans was shot so I believe this is the great price.
