Stator conection
Old Jul 31, 2014 | 04:52 AM
brooksy100's Avatar
brooksy100
Default Stator conection
I have a problem with the stator connecter where it goes into the primary case. If I try to push the connecter on it pushes the other end into the primary case. At the moment I have two small screws holding onto it. Any suggestions. Bike is 85 wide glide. hope someone can help.
Old Jul 31, 2014 | 05:55 AM
Doug S's Avatar
Doug S
The rubber gets soft from the primary oil sometimes, I am very careful not to disturb it when removing the oil filter. Take a black zip tie and wrap it around it close to the case.
Ds
Old Jul 31, 2014 | 06:38 AM
Hackd's Avatar
Hackd
My fix was to take an X-Acto knife and a small pick, pare a bit of the plastic off the stator plug, then insert the pick through the stator plug to hold the female terminals before snapping in the male voltage regulator plug. I made certain the female terminals where snug before doing this by using a pair of small needle nose pliers to squeeze the metal together.
Prior to the home fix, I would go through batteries every two years. The present battery has been in the bike for 8 years.
As another posted, use caution when doing oil filter changes. The design is one of the worst ideas The MoCo could have thought of for this.
Old Jul 31, 2014 | 07:11 AM
brooksy100's Avatar
brooksy100
the oil filter on my 85 is near the gear box not up the front.
Old Jul 31, 2014 | 09:03 AM
Beemervet's Avatar
Beemervet
G'day mate!
It is important to have a complete and solid connection. Otherwise the plug will arc and burn the rubber causing it to harden and also burn the metal. a good connection will then be almost impossible. Get yourself one of clips that keep the plug in place also.
Good luck.
Old Jul 31, 2014 | 02:59 PM
IBDAGRIZ's Avatar
IBDAGRIZ
My solution is a bit longer and a lot more effort, but then you are done with it forever..
I go into the stator and remove the rubber completely and solder in an 8 inch pigtail to the stator. I run this out the hole of the case and silicone it closed inside and out.
I then use waterproof connectors to connect to the regulator. No looseness ever.
I've been doing this to my shovel for over 25 years now and it works perfectly..
Griz
Old Aug 1, 2014 | 11:24 AM
tomfiii's Avatar
tomfiii
Check the connections in the case to see if rubber getting soft and if connectors look bad or discolored,once they go you are quarrantied a problem. If you get the 32 amp upgrade kit it has the case plug that extends above the case.
Old Aug 2, 2014 | 06:42 AM
brooksy100's Avatar
brooksy100
I have just bought the 32 amp system. Thanks for the advice it is the best way to go.
Should finish bike soon.
Regards brooksy100
Old Aug 2, 2014 | 08:45 AM
Throttle_Jockey's Avatar
Throttle_Jockey
I'm with Griz. It's the best way to correct an ancient problem
Old Aug 2, 2014 | 08:47 AM
Tom84FXST's Avatar
Tom84FXST
Newer S&S cases have a set screw to hole the connector from pushing back in the case...pretty simple mod...drill and tap a hole.
