Exhausted
Old Aug 2, 2014 | 07:51 AM
factorybuilt's Avatar
factorybuilt
Default Exhausted
Gentleman, and I use that term loosely, ha!
After the cam bearing repair, the nut that holds front exhaust pipe flange in place, keeps coming loose. I can tell when it starts to loosen because I get a rattle when coming of the throttle. It is the right one, as look you look at it from the the front of the bike. The left one remains tight??
I went through all the heat shields and al the rest of the exhaust system to be sure everything was tight.
Is there something I didn't do right or is there a tip on keeping that nut/stud tight?
Thanks for your thoughts.
Old Aug 2, 2014 | 08:36 AM
Uncle G.'s Avatar
Uncle G.
I've never had that problem, but when I re-install the pipes, I DO have to retighten the exhaust flange nuts once or twice until the new gaskets settle in.
I'll start the bike, run it for a short ride then let the motor cool down and re-torque the flange nuts to 80 inch pounds. After another week or two, I'll check them again. They usually stay after that.
Old Aug 2, 2014 | 08:41 AM
Throttle_Jockey's Avatar
Throttle_Jockey
Is the stud coming loose or the nut? If the stud is coming loose I recommend carefully removing it and Loctite it in the head. I've saw heads damaged due to the stub pulling aluminum threads out of the head.
Old Aug 2, 2014 | 08:45 AM
WP50's Avatar
WP50
The rear pipe on mine would loosen from time to time. I finally put a drop of red locktite on things. Mind ya now just A drop on clean threads. It's holding so far BG WP
Old Aug 9, 2014 | 09:59 AM
factorybuilt
Thank you for the insight.
It is the nut and I still need to tighten it up. Been riding a lot since the weather has been great.
I did not replace the gaskets. Sounds like that might be part of the problem. ??
I do remember when I bought the bike I had that same noise and was told to check on the flange nuts. I did and it took a couple times and the issue went away. Same nut??
Old Aug 9, 2014 | 10:14 AM
ynots's Avatar
ynots
I had the same issue on my bike. On a long trip I had my lower rear one fall completly off. After I replaced it with a new one I had to retighten it twice. Its been holding now for about 5000 miles.I carrying a stubby 1\2" offset wrench everywhere I go
Old Aug 9, 2014 | 10:15 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
I don't see why you can't stick a lock washer under there if you wanted to.
Old Aug 9, 2014 | 10:40 AM
Dr.Hess's Avatar
Dr.Hess
New nut and a lock washer?
Old Aug 10, 2014 | 08:05 AM
factorybuilt
I always wondered why there wasn't a lock washer on those nuts. ??
Thanks again!
Old Aug 10, 2014 | 09:21 AM
texashillcountry
Dirt don't hurt
Thanks again!
I think they are supposed to be self locking.
