clutch problems
Old Aug 3, 2014 | 03:26 PM
BamBam60's Avatar
BamBam60
6th Gear
Default clutch problems
Hello, need some advice. 1994 electric glide. it had the barnett extra clutch assembly it it. i replace with new barnett stock clutch plates because coudnt adjust anymore. the old clutches were worn down. so put new clutches in adjusted as it showed in the manual. but i have nothing ,goes into gear but when release the clutch lever ,nothing. re-adjusted several times. so what am i doing wrong? thank you
Denis
Old Aug 3, 2014 | 04:46 PM
johnjzjz's Avatar
johnjzjz
start over - unadjust the cable all the way in - loose - than the nut in the center of the clutch hub crack the nut counterclockwise than turn the allen counterclockwise till its also loose so you can turn with your fingers - than using your fingers turn it clockwise till it stops than back it off counterclockwise 1/8 of a turn and lock the nut -
note make sure the allen stays put and does not turn when you tighten the nut - paint a timing mark if you have to
than expand the cable adjustment till the clutch lever has just a small amount of play in the lever in its perch
in one week of riding you will need to do it again once the clutch discs are bedded in with the ATF Dextron 3 you Should have used as a primary oil
Old Aug 4, 2014 | 03:52 PM
BamBam60's Avatar
BamBam60
6th Gear
i have re adjusted several times just nothing there.could it be the springs are too week?
Old Aug 4, 2014 | 05:00 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Ok from the beginning step by step what exactly did you do?
Somewhere you forgot a piece or did something wrong and the only way to fix it is to start all over and do it again slowly.
Old Aug 4, 2014 | 05:32 PM
texashillcountry
Dirt don't hurt
This may be a stupid question but did you put the snap ring back on?
Old Aug 4, 2014 | 05:34 PM
92Fatty's Avatar
92Fatty
This is how I do it. Much like John above. I loosen clutch cable until lever just hits handle. The I loosen lock nut on clutch. Then turn in adjuster until you feel movement at the lever. It doesn't hurt to do this more than once. Then when you have so the lever just moves with it at the handlebar back off adjust 1/2 turn. Some back it off a hole turn but I prefer to use 1/2. Then tighten lock nut while holding adjuster with allen wrench. Then adjust lever with cable adjuster. 1/8 recommended play.
Old Aug 4, 2014 | 06:13 PM
Owtlaw's Avatar
Owtlaw
Also make sure that when you bottom out the allen, it's the allen bottoming and not the lock nut hitting the adjuster. Start with the lock nut all the way to the top of the allen to avoid that.
Old Aug 5, 2014 | 07:08 AM
jammerx's Avatar
jammerx
check your throwout bearing... .
Old Aug 5, 2014 | 04:29 PM
BamBam60's Avatar
BamBam60
6th Gear
ok thanks for the help. will try what John and Fatty said to try. yes the snap ring did stay on, i did double checked that. i did look at the throwout bearing, i can see all the bearings, so they are still in there. just weird like i said it did have the extra barnett clutch plate in it. never had a problem adjusting it. now put stock number of clutch plates in it because i didnt know there was the extra plate in it. and nothing. been told to get it in 5th gear and it should be hard to spin the rear wheel when off the ground. and if a it spins easy it could be the shaft. so will try what John and Fatty said first, will keep you updated on results. thank s again
Old Aug 5, 2014 | 05:14 PM
BamBam60's Avatar
BamBam60
6th Gear
ok re-adjusted 4 more times ,still nothing. dont have any extra parts laying there. hope it's not internal . thanks
