Help diagnosing engine bog with fuel coming from carb...
Old Aug 4, 2014 | 08:31 PM
HolyHandGrenade's Avatar
HolyHandGrenade
Default Help diagnosing engine bog with fuel coming from carb...
The story:
-1994 Dyna WG with Mikuni HSR42
-Was running great a few days ago.
-The bike bogged down on me like it was running out of fuel a few days ago. I blipped the throttle a few times and it came out of it. A couple hundreds yards down the road it happened again and came out of it. It ran great for a couple of days after.
-I fueled up the other day. Right after it did it again and continues to do so. It starts right up, idles well, and will run great for a few hundred feet. Then it bogs down, backfires through the carb, and has no power. I also noticed tonight that the carb side of the motor was covered with fuel coming out of the sir cleaner.
Any ideas?
The bike has new plugs, plug wires, coil, and battery. The charging system is functioning properly. It starts and idles, so I'm assuming it's not a spark issue. This leads me to fuel and the carb. No?
Old Aug 4, 2014 | 10:27 PM
Beemervet's Avatar
Beemervet
Rebuild the carb.
Old Aug 5, 2014 | 04:21 AM
HolyHandGrenade
Originally Posted by Beemervet
Rebuild the carb.
Hey, thanks for that. Thats what was I was wondering. What specifically inside the carb is causing this do you think?
Old Aug 5, 2014 | 06:20 AM
Uncle G.'s Avatar
Uncle G.
Sounds like a float height/sticking problem or a worn/dirty/sticking float needle letting the carb flood.
FullNelson
Carburetor Related
Sep 14, 2013 05:29 PM
LawDawg79
Exhaust System Topics
Mar 8, 2011 08:09 AM
kellsbad
May 5, 2009 11:06 PM
chadman10
Apr 6, 2008 09:39 PM
ZX2BY2U
May 29, 2006 03:37 PM
