Evo question
Old Aug 15, 2014 | 07:57 PM
philmore81's Avatar
philmore81
Default Evo question
Hey y'll. I have had my 1985 evo flhtc for about 2 months now and hear a noise in the front of the motor on the right side. It sounds like play in the lifters or something. The thing is I hear the same noise on my 2003 flhtchu/I. I have it about two weeks. The noise is the same just not as loud in the 03. It may be the way Harleys sound being these are my first. I run 20w50 synthetic screaming eagle in the 85 and dyno 20w50 in 03. Any ideas and if I am just looking for problems than just say so because I am good for that!:icon Thanks!
Old Aug 15, 2014 | 10:02 PM
cowboy 51's Avatar
cowboy 51
is it a whine sound or a ticking sound ? on the 03 I would ask the person you got it from if they did any work in the cam area next to right foot board they might have put a gear to gear drive cam set up in there or the se cam plate/oil pump kit, both are good but you'll need to have one or the other being the age of the bike , on the 85 cam is in the same place just a little bit different set up & a little easier to work on
Old Aug 17, 2014 | 07:27 AM
grbrown's Avatar
grbrown
I wouldn't put synth an an '85 engine. That's been around since long before synth became widely available and won't benefit from the stuff. Try a change back to dyno and see if it sounds any better. As for odd noises, they are best diagnosed by an expert who can actually listen to them, like a local friendly indy.
Old Aug 17, 2014 | 07:40 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Unless you know for a fact that the `85 has the upgraded "B" type lifters (with less than 40,000 miles on them), I would replace those lifters.
Old Aug 17, 2014 | 01:22 PM
philmore81's Avatar
philmore81
Thanks y'all!
Old Aug 17, 2014 | 01:35 PM
philmore81's Avatar
philmore81
Should I replace the pushrods too?
Old Aug 17, 2014 | 03:55 PM
Richy8302's Avatar
Richy8302
I replaced all 4 of mine with oem HD ones only cost me 27$ from local HD dealer, so yeah I would.
Old Aug 17, 2014 | 05:42 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
If you are in far enough to change lifters and pushrods I would change the cam bearing as well.
Old Aug 17, 2014 | 06:14 PM
Dan89FLSTC's Avatar
Dan89FLSTC
The cam bearing is already a Torrington B-138.
I still have the original in my `89, over 140,000 miles so far.
I don`t think I have ever heard of a failure.
Only if you see some damage or excessive wear (unlikely).
Old Aug 17, 2014 | 06:36 PM
Uncle G.'s Avatar
Uncle G.
I've never heard of one failing, either, but, as long as I was in there, I'd probably change it anyway, just for peace of mind.
lineman06
Engine Mechanical Topics
May 11, 2015 03:29 PM
philmore81
Aug 16, 2014 12:16 AM
jkauffman86
EVO
22
Aug 16, 2012 04:39 PM
Ridetard
EVO
Apr 1, 2009 02:31 PM
jstacy
Exhaust System Topics
May 22, 2006 04:18 PM
