Superglide no go
Old Aug 27, 2014 | 05:07 PM
machinehed's Avatar
machinehed
I purchased a 90 flt and found broken conductors inside apperantly good looking wires.
Try turning key on and turn bars left and right to look for opens in the harness.
If something shows up , do a pull test on the wires in the harness at the harness pivot point .
Old Jul 10, 2015 | 09:19 PM
RidemyEVO's Avatar
RidemyEVO
Sorry machinehed your post slipped past me. I will be pulling the bike out of storage this weekend and will be following through with all the suggestions.
Old Jul 11, 2015 | 09:23 AM
glidein wide's Avatar
glidein wide
Hurry up!!!winter is on its way!!! It's been tucked away for a whole year? Didn't read entire thread, because it's a year old...
Old Jul 11, 2015 | 12:08 PM
RidemyEVO's Avatar
RidemyEVO
Ya it was put away. I had bought it for my son to ride for when he graduates this year from HVAC course. Not like I was off the road I had my 89 flht.
Old Jul 13, 2015 | 05:25 PM
RidemyEVO's Avatar
RidemyEVO
So far this is what I have found.
- ignition switch connected to harness I get 12 volts at switch where ignition switch connects to harness and both sides of main circuit, breaker ignition turned to off position
- ignition switch connected to harness I get 0 volts at switch red wire where ignition switch connects to harness and both sides of main circuit breaker, ignition turned on position
Its like its grounding when I turn ignition key to On position
- checked ignition switch in with ohms and off on on appears correct.
Suggestions?
Thanks
Old Jul 13, 2015 | 07:00 PM
Dr.Hess's Avatar
Dr.Hess
Check your ground wire, from the battery negative to wherever it goes, probably bottom of the motor or trans area. Look closely, take apart, clean, grease, put back together the battery cable at the battery and the other end.
Old Jul 13, 2015 | 08:12 PM
RidemyEVO's Avatar
RidemyEVO
Ok will do Dr Hess.
I also just tried the ignition switch off my 2002 superglide and same results and the switch off my 1997 superglide on the 2002 superglide and it worked so eliminates faulty switch.
Old Jul 13, 2015 | 09:36 PM
RidemyEVO's Avatar
RidemyEVO
Found the problem .
Unfortunately when I pulled the nut off the starter to put loose wire back on the washer and nut fell under the starter to know where's ville.
Old Jul 14, 2015 | 08:43 AM
Dr.Hess's Avatar
Dr.Hess
So it's working now?
Old Jul 14, 2015 | 08:53 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Only if he found (or replaced) the nut that holds it to the starter.
