Engine Black
Old Sep 4, 2014 | 08:14 AM
flhchaz's Avatar
flhchaz
Default Engine Black
Fellow evo-ites. Has anyone used any engine paint to touch up the factory engine black? I know the MoCo sells a touch up bottle, but I was wondering if anyone has used anything other than the factory stuff.
Old Sep 4, 2014 | 08:41 AM
4_stroke's Avatar
4_stroke
There are other crinkle black options out there (Hycote, VHT) . IMO the most important thing is getting a good etch primer in first otherwise it just flakes off.
Old Sep 4, 2014 | 09:59 AM
Throttle_Jockey's Avatar
Throttle_Jockey
Read the directions on the can. VHT recommends pre heating before spraying and "baking" after spraying for best results (i.e. A heat lamp/halogen shop light). The hardest part with a engine still in the bike is retaining the machined fins on the heads/cylinders, and of course masking everything off to prevent unwanted over spray.
Old Sep 4, 2014 | 10:11 AM
4_stroke's Avatar
4_stroke
If its just touching in chips then I squirt some into the lid and put it on with a detail paint brush. Much les drama than trying to spray it on.
Old Sep 4, 2014 | 01:12 PM
Richy8302's Avatar
Richy8302
I used a couple coats of 2000+ degree flat black engine paint, then a couple coats of industrial strength gloss black enamel. Has held up well......
Old Sep 4, 2014 | 06:10 PM
01fxdxt's Avatar
01fxdxt
For small areas ,I was able to get a near perfect match with Testors model paint,gloss black,flat black,1/2 and 1/2 then added some grit that is used for floor paint.If I didn't tell someone they never would have noticed.
Old Sep 4, 2014 | 06:30 PM
Throttle_Jockey
This is some very cleaver ingenuity. Kudos sir.
Old Sep 4, 2014 | 07:00 PM
Harleydawgz's Avatar
Harleydawgz
Stupid question and a point.....wouldn't that have to be high heat paint and is anyone familiar with "S100" spray for the engine black? Is it good or not really? Sorry if I got a little off topic. Thanks.
Old Sep 4, 2014 | 08:22 PM
Beemervet's Avatar
Beemervet
S100 restores the deep black on the factory paint. Works great.
Old Sep 4, 2014 | 08:36 PM
Harleydawgz
Thanks, Beemervet.
