belt drive problem
Old Sep 8, 2014 | 05:12 AM
Tom84FXST's Avatar
Tom84FXST
Will the ultima pulley insert interchange with a BDL part?
http://www.bikerparts-superstore.com...rSAhoCNRPw_wcB
Old Sep 8, 2014 | 09:59 AM
D_gyver's Avatar
D_gyver
no it wont I thought of that
Old Sep 8, 2014 | 10:08 AM
D_gyver's Avatar
D_gyver
ok here is what I found out the Rockwell rating on the primo insert was 64 HRCW and the ultima was 38 HRCW so this might be it. they are going to harden it for me ill pick it up wed. and see how it goes
Old Sep 8, 2014 | 05:12 PM
junglejoe's Avatar
junglejoe
Not any help here D, but did I read somewhere where you put red on the splines? Just wondering why ..
Old Sep 8, 2014 | 10:33 PM
D_gyver's Avatar
D_gyver
putting red Loctite on the clutch and motor splines is a trick I learned from an old timer its suppose to minimize spline wear on open belts if you look at bdl instructions they now tell you to do this. so there might be something to it. im not sure if it really works or not never had a problem with this until now
Old Sep 9, 2014 | 08:26 AM
Throttle_Jockey's Avatar
Throttle_Jockey
IMO with red on the splines in theory could help keep moisture out and prevent corrosion.
Old Sep 9, 2014 | 03:18 PM
junglejoe's Avatar
junglejoe
If I'm thinking correctly, the splines on the shaft where the pulley slides on? When I done my, they said put wheel bearing grease in there, and I did, and it was quieter, but guess what, the chit gets hot and now has started slinging the chit EVERYWHERE!! they didn't mention all the business! Everytime I ride it, I have to wipe it down because the grease has slung all over the back of the bike! Going to take it apart and clean whats left of the chit outa there!!
Old Sep 9, 2014 | 05:24 PM
0734's Avatar
0734
I just had to try running a belt-drive once.....only once. I learned my lesson. We all should know that MOCO tried it years ago and failed miserably. I think that if it was a way for Harley and Gates to figure this out and make one that would last...they would have figured it out a long time ago, but they never did so we're still stuck with the chain-drive. The short time that I could keep mine together was a dream. Smooth shifting and quite running....while it ran.
I realize the subject here concerns "sporting purposes" and not necessarily durability/longevity purposes. The only experience I had was with a BDL unit, which was a POS.
Old Sep 9, 2014 | 06:46 PM
D_gyver's Avatar
D_gyver
sorry to hear you had bad luck with it. my bdl drive on the shovel has only failed me one time and that was a broken belt. out of all the belt drives ive used over the years this is the only one that is giving me problems.
Old Sep 9, 2014 | 07:12 PM
johnjzjz's Avatar
johnjzjz
in the 2 weeks i am doing this no one has left the shop after a check over for a cross country trip with a primary chain and tools to change it
BUT did i say BUT every one who left with a front belt left with an extra belt and tools to change it
