HD cylinders on S&S case?
Old Sep 9, 2014 | 05:19 PM
jsbridgew's Avatar
jsbridgew
Default HD cylinders on S&S case?
so i've installed wiseco pistons in my HD cylinders and I'm ready to drop jugs down on case with cometics, but i stopped.... i really don't want to tear this engine down again...and i'm looking at oil passage holes, and I don't see any real difference between S&S and Harley...S&S passages are a bit larger, but that's it
should i install the pigtails at the bottom of these HD cylinders, or leave them alone and hope for the best, trusting that S&S has pulled through in designing this case so that i don't get any base leaks?
dilemna
Old Sep 9, 2014 | 07:28 PM
johnjzjz's Avatar
johnjzjz
dissimilar techniques in the way the 2 companys approach the same thing in machining and sizes have always been an issue, we have learned to buy into all or none of it
having said that i have not had a leak issue with S&S and OEM harley mix and match
would it hurt to add the sleave - NO
Old Sep 9, 2014 | 09:17 PM
misfitJason's Avatar
misfitJason
Helpful info. I'm not the op but thanks for that
Old Sep 10, 2014 | 07:14 AM
jsbridgew's Avatar
jsbridgew
yes, good info....thank you John!
Wheelup
Apr 24, 2020 07:59 PM
dtwisdale
Exhaust System Topics
May 13, 2013 09:25 PM
Wireguided
Nov 7, 2012 10:42 PM
t059736
May 3, 2011 08:40 AM
Rink-A-Dink
Aug 16, 2010 03:38 PM
