4" pistons
Old May 2, 2007 | 10:45 PM
srob's Avatar
srob
Default 4" pistons
Just wondering if anyone has installed 4" pistons in a tc88 without stroking the motor or milling cases. I'm running a 95" kit now, but I want pistons the size of whiskey barrells. I can get 4.06" standard bore pistons, but was wondering about the cases. I don't want to decrease the life of the motor by stroking it. Can the stock jugs be bored big enough without concern? I might be getting a little thin.
Old May 3, 2007 | 10:33 AM
roadglide65's Avatar
roadglide65
Default RE: 4" pistons
Can't be done with out boreing cases. and new jugs. 4" bore and 4" stroke gets you to 100" andwww.axtellsales.comsells a kit for it but could not see why? When you could bore the cases to 4.125 and keep the same crank and have 107" www.revperf.com has a good kit that you might want to look at.The biggest you can go with out boreing the cases is 98" and you will still need new jugs.
Old May 4, 2007 | 03:07 PM
srob's Avatar
srob
thanks for the info. Sending out a set of stock heads and cases to be reworked. going with new jugs/pistons and new carb.
Old May 5, 2007 | 10:15 AM
jakazz's Avatar
jakazz
I heard that you cant bore stock jugs out to 4"-3.78" is the max......
And if you get a kit with the right jugs that would be sweet because they say a square motor is huge on torque.
James Daniels
Engine Mechanical Topics
Nov 3, 2017 06:09 AM
jmb79
Nov 6, 2014 07:23 AM
aggiejason
May 19, 2013 07:50 AM
black classic
Apr 8, 2012 08:32 PM
Garcou
Sep 7, 2010 07:32 AM
