Sponsored by: Jekill and Hyde
reversing stage 1 question
Old 05-18-2007, 06:38 PM
robcorp421's Avatar
robcorp421
robcorp421 is offline
6th Gear
Default reversing stage 1 question
When purchased in 2005, astage 1 was addedat dealership for a 2005 Electra Glide. I recently reinstalledthe original stock mufflers. Do Ineed to reverse anything else that was donewhen the stage 1 was installed? Thanks, Bob
Old 05-18-2007, 06:44 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
Default RE: reversing stage 1 question
Did they do the ECM down load with it...if so you will be a bit rich in the AFR, not a great deal but a bit rich.
Old 05-18-2007, 06:57 PM
robcorp421's Avatar
robcorp421
6th Gear
Is it runing rich going to cause a problem. should i go back to dealer?
Old 05-18-2007, 07:43 PM
Doc 1's Avatar
Doc 1
Doc 1 is offline
The stage one download is 5% richer over the Base map...I personally don't think it will hurt the bikes performance as much as it's going to lower your gas mileage. The mileage will drop to around 39 to 40 mpg...that is an educated guess. If it bothers you to run a bit richer the dealer can put a stock download in the ECM but be ready for a $150.00 charge.
Sagostino
07-26-2014 02:49 AM
D.Stewart
11-16-2012 10:21 PM
yzf1999
07-06-2012 08:15 PM
2008FLHP
03-31-2008 04:29 PM
WARG
12-29-2006 07:01 PM
Quick Reply: reversing stage 1 question
