I'm thinking of getting the Pro pipe for my 15 street glide. Right now I have magna flow pro duel header with the top gun mufflers and stage 1ac. I had it dynoed by Doc and ended up with 79.88 hp and 101.9 torque. Will this pipe perform better and help regain some bottom end
If you'll read up on all the advantages that a good 2 into 1 system offers by using the search function, you'll have your answer. I'd go with the Fatcat from D&D over the V&H junk any day.
Someone may be able to comment on the exact power numbers that pipe will make, but we can say that your Pro Dual system was designed with tuned pipe lengths, which enabled us to match the same power gains of most 2-1 exhausts out there!
It all depends where in the rpm range one wants the max torque. I like the low end torque between 2500-3500 rpm,which is where I do most of my riding. With the MF pro duel I have, max torque is at 3500-4000 rpm.
I have seen pro pipe dyno results with max hp 90-92 and torque between 104-106. The MF pro duel head pipe and the top gun mufflers that I have on my bike that was dynoed by Doc, ended up with 79.88hp and 101.9 max torque.
So there is some difference in numbers.Im not bashing MF, They make quilty exhaust, Im thinking that the pro pipe will better suit the way I ride. Im sure there is better pipes out there,but I got a good deal on the pro pipe and decided to give it a try and sell which ever I dont use
