Carb Question
Old Oct 18, 2005 | 11:02 PM
Naz_Man's Avatar
Naz_Man
Default Carb Question
Check this out before you reply Click here
Question: Would buying a new carb like a SS or something fix this problem?
Old Oct 19, 2005 | 01:24 AM
HDF Tech's Avatar
HDF Tech
Default RE: Carb Question
Not necesarily, you could have the software problem mentioned in the other post, check here https://www.hdforums.com/m_73069/tm.htm
Old Oct 21, 2005 | 12:05 PM
HDWRENCH's Avatar
HDWRENCH
Ok I read through it and posted on the not need rejetting post, but I did not see anywhere if you checked for a intake leak?? I really would check that first, to ensure you are ok with the seals, then move on from there.
The 45 pilot should work fine, however due to the carb being a production item, many times the need to balance the transfer ports is needed. This is done by drilling a very small hole in throttle plate .050 up from transfers. This is one of many things I do when I prep a carb for a customer. Also check the pilot for any flashing inside the jet it's self as that will cause big trouble for you as well. YOu can use torch cleaning tool for this. Many times when the holes are drilled a small part of the brass gets lodged in the jet.
Swapping to a S&S is not going to help you if fact there are more trouble to tune , due to the fact they are only a 2 jet carb, verse's your 3 jet
Skiprrrdog
EVO
May 17, 2016 06:00 AM
pacman552sd
Carburetor Related
Jun 3, 2015 10:39 PM
alitterit
Jul 21, 2012 03:49 PM
timberwolfz28
Aug 26, 2008 07:37 PM
tmr931
Ironhead
Oct 6, 2007 12:59 AM
