DIY tapered muffler baffles
Old Sep 11, 2019 | 12:55 PM
fat00boy's Avatar
fat00boy
Default DIY tapered muffler baffles
I couldn't stand the sound of my Pro Pipe anymore, so I put the stock pipes back on. That didn't cut it and I didn't want to spend $300+ for mufflers I might not like so I took a 1 3/4" hole saw and gutted the mufflers. Not the sound I was looking for either. What I ended up doing is going to a muffler shop and had them cut 2 pieces of 1 1/2"" tubing 16" long and expand each end to 1 3/4". Then I cut a 1 1/4" X 2 1/2" U out and bent it down as a deflector. I drilled 99 3/16" holes in the baffles. These have a nice deep sound at idle and are quiet going down the road. I did end up driving a screwdriver in and opened up the flap about 1/4" just to get a little more sound. And, I can always open the baffle up or close it back down. Total investment $20 to muffler shop and probably 2 hrs. time. It's worth a shot if you're just looking for a little more tone. It seems to help performance as well.
Old Oct 10, 2019 | 10:12 PM
1999 flstf's Avatar
1999 flstf
does it matter which way the angle cut with the flap is facing? to the front of the bike or or back. i might try this on my baffles i had to have installed to pass state inspection. i have drag pipes on my bike.
Old Oct 14, 2019 | 07:38 AM
fat00boy's Avatar
fat00boy
Flap goes towards the front. I think there are a few companies that already make baffles for drag pipes.
Old Oct 14, 2019 | 09:03 PM
1999 flstf's Avatar
1999 flstf
thanks. the baffles they installed are coming into it, when you get after it but not so much just cruising or idle. think ill try this before cutting the baffles in half. at idle it makes a weird whooshing sound.
Old Oct 15, 2019 | 06:42 AM
bustert's Avatar
bustert
there are many ways to make baffles. the perf tube and redirection is restrictive. i prefer flow through and change of direction. the flow through is less restrictive and the change of direction fights reversion.
http://xlforum.net/forums/showthread.php?t=1996355
Old Oct 15, 2019 | 09:04 PM
1999 flstf's Avatar
1999 flstf
im going to pull the baffles out, in the next coupe days and i will take some pics of what is in there. i would like some ideas on what to do with them. besides not put them back in. i will take a ride with straight drag pipes, haven't been able to do that since i bought the bike this summer.
Jimmyess333
Jan 22, 2018 10:11 PM
cbertalotto
Sep 7, 2014 11:35 PM
TORQUEY
Feb 16, 2011 07:54 PM
editbrain
Nov 9, 2010 10:33 AM
dcookiej
Apr 20, 2009 07:57 PM
