Engine Ranges
Old Aug 13, 2007 | 11:28 AM
pauletich's Avatar
pauletich
Default Engine Ranges
A lot of people have been talking about low-range, mid-range and high range for an engine. I am looking at getting a gear cam kit and they are asking me what range I want improvement in.
Can some clear up and clarify what the ranges are.
Low range- 0 - 30 MPH ?? and so on.
Old Aug 13, 2007 | 12:04 PM
Doc 1's Avatar
Doc 1
Default RE: Engine Ranges
Low Range up to 2000 rpm
Mid Range from 2000 rpm to 4000 rpm
High Rangefrom 4000 rpmto 6000 rpm
Old Aug 13, 2007 | 12:06 PM
pauletich's Avatar
pauletich
Thanks Doc. Do you have any recommendations for good Mid Range CAMS?
Old Aug 13, 2007 | 02:35 PM
Kingofcubes's Avatar
Kingofcubes
For mid range we like the new RR525 gear drive cam. It is designed to be a torque cam (bump up from a 37) for little or no head work.
Old Aug 13, 2007 | 03:20 PM
xxxflhrci's Avatar
xxxflhrci
I like the Andrews 26G for midrange.
Old Aug 13, 2007 | 04:31 PM
pauletich's Avatar
pauletich
Thanks, I was thinking Andrews 37. Is this a good choice?
Old Aug 14, 2007 | 12:42 AM
Doc 1's Avatar
Doc 1
I haven't tried Randys .525 cam myself but he is a smart man so there is one choice. I lean to the 26---37---tw6. The tw6 and 37 need a bumb up in the compression and a small bit of head work will really let the cam come unleashed
Old Aug 14, 2007 | 10:58 AM
pauletich's Avatar
pauletich
Thanks, Do all new cams need head work? I was hoping just to get a CAM kit, no head work.
Old Aug 14, 2007 | 12:54 PM
Doc 1's Avatar
Doc 1
I'd go with the Andrews 26 cam then.....80/90 is very consistent with a 95 'or 96' motor
Old Aug 14, 2007 | 02:10 PM
pauletich's Avatar
pauletich
Thank you, I will look into the 26
