Engine Missing
Old Dec 18, 2005 | 11:05 PM
bdog1234's Avatar
bdog1234
6th Gear
Default Engine Missing
Hello, this is my first post here. I bought my first Harley last week, a 2000 FXD. I know very little about them but I like it a lot. I am having a problem with the way it is running. It runs perfect at idle, and under heavy throttle, but when cruising at medium range rpms it has a bad miss. It is bad enough that the bike shakes and sputters. If you give it the gas it completely goes away. Any idea what this might be?
Old Dec 18, 2005 | 11:51 PM
8 UP's Avatar
8 UP
Default RE: Engine Missing
Check for air leaks in the intake around the heads & carb, vacume line.
Also plugs & wires.
Check your carb jets & A/cleaner.
Old Dec 19, 2005 | 03:53 AM
usblues101's Avatar
usblues101
Second 8UP.also check F/A adjuster[behind carb],about 2 1/2 turns out,what color are plugs?
Old Dec 19, 2005 | 04:02 AM
usblues101's Avatar
usblues101
I just realized,if this is your first HD,you MAYBE are lugging the motor....know what I mean? Bob
Old Dec 19, 2005 | 05:59 AM
geno3j's Avatar
geno3j
8Up I think hit it on the head, hope your not bogging it down it is easy to do with first Harley "Let her Purr", Have you checked your Plugs? Are you running a high enough Octane? I know if I put low octanne in my bike she runs like a pig. Make sure you spend the extra and feed the girl right.
Hope these help
Geno
Old Apr 6, 2009 | 07:49 PM
quigley's Avatar
quigley
Did you ever find the problem? I'm having the same problem right now.
Thanks Quigley
Kakha Barnovi
Jan 12, 2019 05:14 PM
backwoodsdave
Shovelhead
Jun 27, 2018 12:35 AM
cocheese72
Nov 5, 2012 11:19 AM
aeproberts
Mar 12, 2009 02:45 PM
labelkil1s
Sep 6, 2007 09:35 AM
