Hypercharger issues...Help!
Old Nov 10, 2007 | 07:37 AM
HocusFocus's Avatar
HocusFocus
Default Hypercharger issues...Help!
I recently had to disassemble my hypercharger to get it powdercoated. After putting it back together, I noticed that my butterflies aren't moving. Just wondering if this is caused by a bad seal in the vacuum pod. Can someone help me? Please??
Will it cause damage to ride with the butterflies wide open? Wouldn't that cause it to run lean?
Old Nov 10, 2007 | 09:56 AM
pled55's Avatar
pled55
Default RE: Hypercharger issues...Help!
if you got the shaft powdercoated it may need to be removed a little so the butterflies can move
Old Nov 10, 2007 | 11:32 AM
xxxflhrci's Avatar
xxxflhrci
No, it won't run lean with the butterfly's stuck open. They are there for show, not go.
Old Nov 11, 2007 | 06:28 AM
powdercoater's Avatar
powdercoater
It sounds like the moving parts were powder coated while still assembled. Kinda like painting a window in your house while it's closed, the powder coat will cause problems with free movement... especially very small parts like that. To get the best possible results, always completely disassemble parts prior to powder coating and make sure your powder coater knows what needs to be masked off.
Old Nov 12, 2007 | 06:10 AM
HocusFocus's Avatar
HocusFocus
I totally disassembled the unit before powdercoating. The butterflies move freely when I press them with my finger. I think the problem is in the vacuum pod. The diaphram was a bit wrinkled when I took it apart again, I'm just going to replace that whole set up. It only cost $14 to replace, so why not.
cycler
Aug 29, 2014 11:40 AM
chgofirefighter
Feb 10, 2014 11:46 AM
Krazy8s
Aug 26, 2010 01:17 PM
RTBrandy
Aug 10, 2009 11:56 AM
ky_ace
Mar 30, 2009 10:07 PM
