Screaming Eagle Adj Push Rods
Old Dec 22, 2007 | 01:28 PM
wadejesu's Avatar
wadejesu
Default Screaming Eagle Adj Push Rods
Anybody know the diameter of screaming eagle push rods?
Old Dec 22, 2007 | 06:16 PM
rtcook's Avatar
rtcook
Default RE: Screaming Eagle Adj Push Rods
I just bought these for my Road King. I am in the process of putting them on. I will get a measurement for you when I head back out to the garage.
Roger
Old Dec 22, 2007 | 06:29 PM
rtcook's Avatar
rtcook
.440 diameter on the rod itself.
.535 on the adjuster nut.
Hope that helps,
Roger
Old Dec 23, 2007 | 08:16 AM
wadejesu's Avatar
wadejesu
Thanks, I have some Zipper's adj rods, which contact upper push rod tube, SoI have to move rocker arm plate closer to cam side of engine to avoid contact. You should check your clearance.
Old Dec 23, 2007 | 09:27 AM
rtcook's Avatar
rtcook
Haven't got that far yet, but these are supposed to be sure fit replacements. Are the Zippers rod diameter larger than the Screamin' Eagles? The SE's come with new rod tubes that are different (longer) than stock. Although some of the original parts are reused.
Roger
Old Dec 23, 2007 | 10:35 AM
wadejesu's Avatar
wadejesu
The Zippers are slimmer at the top fatter in the middle, The rod tubes you got are shorter so you can hold up covers with clothes pin during adjustment.
Old Dec 23, 2007 | 02:21 PM
rtcook's Avatar
rtcook
Mine are in. Does not seem to have any kind of clearance issues. They worked out great. Yes, I could hold up the tubes with a clamp to adjust them.
Roger
Sparra
Engine Mechanical Topics
Aug 16, 2018 12:08 AM
asahi1234
Jan 30, 2011 03:59 PM
gooberhd1
Nov 7, 2007 09:36 AM
gamb
Oct 3, 2007 06:13 PM
wideglidedan
May 8, 2006 09:23 PM
