idle adjustment
Old Jan 8, 2006 | 09:25 PM
Otter
Guest
Posts: n/a
Default idle adjustment
OK - this is a real newbie kinda question....
Not familliar with the adjustment of my CV Carb. It is idling a bit high and I would like to make an adjustment. I see a brass adjustment screw (lower rear) and a thumb screw on the end of rubber tubing just above it- not sure what these are for.
The bike has only ~200 miles on it, I'm guessing it will change as break-in continues?
Old Jan 8, 2006 | 09:47 PM
HDF Tech's Avatar
HDF Tech
Default RE: idle adjustment
You'll find the idle speed adjustment screw on the right side of the carb towards the front of the bike. It has a gold color screw that will accept a phillips or regular screw driver and is pointing upwards at a round a 45* angle . To lower the idle, turn it counterclockwise.
Old Jan 8, 2006 | 11:55 PM
Otter
Guest
Posts: n/a
gottcha - thanks!!
BTW - what is the thumbscrew in the rubber hose????
Old Jan 9, 2006 | 09:00 PM
John TN's Avatar
John TN
Sounds like you might have a mikuni carb there, the thumbscrew would be the idle adjustment, the hose would cover a flex line to the idle adjust screw on the side of the carb if so, see where it connects to on the side of the carb.
Old Jan 10, 2006 | 12:45 AM
Otter
Guest
Posts: n/a
OK - so it sounds right. The flex line connects to the left side (rear of the bike). I turn it like 1 turn in or out and the idle increases slightly regardless which direction. Turning further in either direction seems to have no effect? Dealer installed a 42mm carb kit - not sure what make...
Thanks for the help!!
reservoir dog
EVO
Nov 9, 2013 01:38 PM
HarleyReece
EVO
20
Jun 26, 2012 06:58 PM
nwpwr22
Ironhead
May 30, 2012 03:15 PM
kd4tsc
20
Feb 8, 2010 07:42 PM
maineultraclassic
Jul 23, 2009 09:00 PM
