andrews 26 and HQ0034
What do you guys think of these cams? what one would you recommend for a bagger, which one would be better for later mods such as increased compression, probably no more than 9.5 to 1, big bore kit, port heads, What are the differences between the 2, what ones do you guys prefer
RE: andrews 26 and HQ0034
The 26's are great bolt-in's. They are designed to work with stock heads & @ stock compression and the work very well ~ when used as intended.
The 0034's will prove to be much better if you do go with heads & increased compression.
I have used both many times.
Actually these cams are almost identical. The intake closes at 35 abdc on the 26 and the HQ0034 closes at 36. Both of these will start to make good torque around 2300 rpm. The lift is the same and the only real difference is the amount of overlap. The 26 has 20 degrees and the 0034 has 39 degrees. What it boils down to is the 26 should get slighly better mileage since the overlap is less and if you ride at low rpm a lot you will have less reversion.
Hey, Steve youve have both the 26 and the 0034in your bike, right,which one did you prefer, I think I seen somewhere you are switching to a woods tw6, was there something you dint like about the 0034 or just want something different with different characteristics, Thanks Todd
