Help id'ing a cam
Old Jan 22, 2008 | 09:05 PM
Fatboy931's Avatar
Fatboy931
Default Help id'ing a cam
I need some help identifying a cam. I bought the bike used from dealer so I don't have any history on it. It.s a 93 Fatboy with 10 to 1 Wiseco pistons. The cam that I pulled out has the part # FB316-2B-33-95-CR engraved on the last two lobes. The only other marking is on the gear and that is #70004. I have to replace the cam and was trying to find out what it was without breaking out a degree wheel and dial indicator. I'll measure the base circle and lobe so I know the lift. The springs in the heads which have been worked over do not appear to be stock. They have two springs and a damper. Any help would be much appreciated.
Old Jan 23, 2008 | 10:51 PM
fltr00's Avatar
fltr00
2nd Gear
Default RE: Help id'ing a cam
That should be a Crane 316-2B cam .490 lift. It is a decent bolt in cam. It is an early model so the new part number is different.
theduroche
EVO
Mar 30, 2019 11:36 PM
rough rider
Oct 14, 2010 12:17 PM
roadgliderick
Panhead
Aug 5, 2010 08:43 PM
518Train
Feb 18, 2010 05:49 PM
90evo
Dec 25, 2009 06:16 PM
