Compression Ratio?
The motor has been upgraded to 95" using H-D Screamin' Eagle kits and components, including the Stage II Big Bore Kit, Screamin' Eagle Pro Performance Heads, and SE257 cams, instead of the included SE 203 Cams. A Power commander manages fuel mapping changes. I "think" I'm running about a 10:1 ratio, based on the table in the catalog. I'm pretty sure I want to go with S&S Gear Drive cams, as long as the run-out on my crank is less than .003. With that all said, I've got a couple of questions:
With H-D Stage II 1550cc kit 29859-04, including the pistons that come with the kit, and Screamin' Eagle Pro Performance Cylinder Heads (p/n) 16953-99C, and no other modifications,I believe the compression ratio should be 10:1.
Can anyone confirm that value?
Will I see a major torque (and thereby rideability) improvement if I go with the 570G S&S cams? I've been pointed toward the S&S 570G cam set, as S&S recommends it with up to 10:1 compression. The heads support up to .575" valve lift, and the 570s come it at .570" (duh!) Reviewing the specs of this cam, there isn't a great difference between the duration of the SE257 (252intake/260exhaust) as compared to 240i and 255e, but S&S offers a 546G, with an honorable lift,(.546"), but greatly reduced duration (240i and 237e). The S&S web site doesn't detail what performance to expect with the 546G, so I'm coming to the forum, looking for advice, and experience with this setup.
Does anyone have experience with the 546G and 570G cams?
Thanks in advance!
Steve
I'm in the process of swithing from chains to gears inmy motor now.
You will need a different PC map, the one you have now may have too much timming.
A good place to do some research would be, www.niterider.com
