I have a 99 softail with a stock Evo. I need to replace my rear cylinder and head, and I want to upgrade and get a big bore kit. Just cylinders, pistons, and heads, no bottom end. Does anyone know a good kit that matches the stock black wrinkle finish?
There isn't a big bore kit for the EVO. Unless you want to bore cases for larger bore cylinders. Wiseco IIRC has a 88" kit, pistins and cylinders but again IIRC you would need to bore the cases.
