Big bore kits
It's all about airflow not CI. Spend money for better flowing heads, cams, and throttlebody, you will be better with 95" kit but not because of cubes but more to do with forged piston versus cast. Somwhere on this site is a thread about 125 HP 95" motor.
A good aftermarket kit build will net you really good gains. Headquarters, GMR, and a whole host of other builders put some really nice kits together and know what works well with what. A mismatched component build will dissapoint you in the end. I am not a pro builder, but have done enough of em to know that it takes a whole lot of research to get the right components if not going with a kit.
I went with HQ due to service and reputation, but there are others, so do your research.
A compatible set of 95" components will deliver reliability with exciting performance - every time!
S2 = 100/100 H&T
S2-1/2 = 105-108 H&T
S4 = 108-110 but rev 3 seconds quicker than stock
S5 = 118-122 H&T
These are high torque kits with very good VE, nothing obnoxious, easy starting, and cool running.
But I wouldn't bore out Harley stock 3.750 any further than 3.935 (3 15/16 in). Because the spout that goes into the case gets thinner and thinner. Harley walls get pretty thin about here also. Why there are after market, much thicker cylinder liner, makers around.
