air cleaner modifications
Old Feb 27, 2008 | 09:44 PM
edfromptown's Avatar
edfromptown
Default air cleaner modifications
t/c 96" softail std airbreather. i'm an inside machnist and modifying the air
breather is no prob. i have cobra fuel management for 02 sensors in place
and running right. so , if i open up the aircleaner ( like mill some extra pockets
next to the existing ones ) i can richen up the mixture if i need too. question is
has anyone expereinced this type of mod . 1 dont wont to spend a 150$ for
an aftermarket a/c if i dont have too. all comments welcome
Ed
Old Feb 27, 2008 | 10:37 PM
Ultra Rider 03's Avatar
Ultra Rider 03
Default RE: air cleaner modifications
Yea I did this to my 03 Ultra 103. I put 13 1.5 holes in the backing plate and around the lower edge. I also put a K&N stock size filter in it, works well and still looks stock.
Old Feb 27, 2008 | 10:38 PM
big mahk's Avatar
big mahk
Hey Ed
What you're thinking about doing will probably help your AC a bit but there's more involved in making a great suckah. The element material, depth of the filter, and the shape of the carb or efi inlet play major roles in how the performance turns out. Check out the Doherty PACCair cleaner. It got huge raves from most of the major mags and what it appears to me the real key piece of their set up is the integral 1 1/2" velocity stack inside the filter. You being a machinist could make a similar set up for your stocker but you'd still be stuck with the low flow element and other restrictions. The mags that dyno tested the Doherty unit showed up to 11 hp gain at the rear wheel over stock. That's huge for the $290 investment. The Feb. 08 issue of American Iron Magazine had a Donny Peterson article on the finer points of air cleaner technology including the Doherty unit. Whether you buy one or make one there's a wealth of info in that article.
Good Luck from Oaktown
Burbur2
Dec 25, 2024 04:38 AM
Joe_G
Jul 31, 2014 03:17 PM
jdsmitty10
May 3, 2010 12:50 PM
plane
Oct 31, 2009 06:36 PM
crock921
May 12, 2008 08:14 AM
